Vintage tyre and tu...
[Closed] Vintage tyre and tube size sources
6 Users
I just bought an old (1974 ish) Peugeot bike for my daughter. It's lovely. However, it needs a new front inner tube (and at some point it'll need new tyres no doubt).
I popped into my LBS earlier to see if they had anything in stock, but sadly they didn't. I have a few more shops to try, but thought I'd test the knowledge of STW until I manage to ring around.
I attach a photo of the bike and a close-up of the front tyre. The figures read:-
37-490 (550 38A)
Can anyone fill me in on where I might get the right size tubes for these? Amazon is ideal, particularly if there is something with next-day delivery as I was hoping to go out for a bike ride this weekend with my daughter on her new steed.
Posted : 26/05/2017 10:22 am
A 24" x 1.5" tube will fit if it's a 550mm BSD, if it's 490mm is might be closer to 22". LBS or decathlon should have something.
https://www.sheldonbrown.com/tire-sizing.html Sheldon doesn't list it so it really must be niche!
Posted : 26/05/2017 10:40 am
I found that website too but struggled to see the exact same numbers. There is a table half way down the page that lists ISO sizes, and in there, I can see a 490mm 550A tyre, but not really sure if that's the same thing.
I don't really understand the two sets of figures on the tyre wall. 490 is very different to 550.
Posted : 26/05/2017 10:49 am
Those rims....I remember riding bikes with rims like that. Awful things if you ever want to stop.
Don't go out in the rain without checking your dental insurance first.
Posted : 26/05/2017 10:52 am
Haha. They do look very shiny!
Still, we won't be riding anywhere if I can't get a darn tube!
Posted : 26/05/2017 10:55 am
I didn't scroll down that far, 490 will be the rim diameter, 550 will be the approximate outer diameter (in the same way 700 used to be nominally what road bikes were). A/B/C I think referred to the width of the rim, so 700c was a skinny rim, 550A was a chunky rim, but 550c would be the same outer diameter (i.e fit in the same frame) but a bigger diameter rim with a skinny tyre.
Posted : 26/05/2017 11:05 am
I'm amazed that the bike shop didn't just whip out a tape measure and sell you the closest, common sized tube.
Anyhow, for future reference, it looks like [url= https://www.sjscycles.co.uk/tyres-550a-nl-489-490/ ]St John Street cycles have a small range of tyres. [/url]
Posted : 26/05/2017 11:15 am
A Schwalbe AV8 will fit. I have one in my hand. If you can't find one somewhere drop me a DM.
Posted : 26/05/2017 11:29 am
Thanks simondbarnes. I've just found one of those on Amazon so I have ordered and will hopefully get it tomorrow!
Cheers.
Posted : 26/05/2017 11:37 am
If it is like a lot of other old French bikes, even ones originally sold in the UK. It will probably have French size threads, instead of British sizes.
M14 pedal thread instead of 9/16" x 20 tpi .
M25 x 1 headset instead of 25,4 x 24tpi.
M35 x 1 bottom bracket instead of 1 3/8" x 24 tpi, and right hand thread both sides.
Plus the handle bar stem will be 22mm instead of 7/8" fit into the steerer tube.
Posted : 26/05/2017 3:08 pm
