Vibrating rear brak...
Vibrating rear brake
6 Users
2 Reactions
 FOG
We are all used to tales of noisy brakes but my rear actually vibrates so you can feel it all the way to the seat. It is a Guide RE on a Vitus E Sentier. I was told reducing disc size would help so I went from 200mm to 180 both Centreline with no effect. I have changed pads, wheel bearings and have run out of ideas. Any suggestions?
Posted : 29/07/2024 11:48 am
Stupid suggestion probably, but have you checked the brake is actually bolted on tight? Ditto is rear wheel tight?
Posted : 29/07/2024 1:14 pm
I had this with SRAM Level brakes on my Trek Superfly.
Nothing cured it until I taped a lead wheel balancing weight to the seatstay which calmed it down somewhat, but replacing the brakes with Deore ultimately solved it.
Posted : 29/07/2024 1:31 pm
 nbt
sounds lke something not aligned properly. Have the brake moutns been faced correctly, is the caliper properly fitted?
Posted : 29/07/2024 1:52 pm
I had this issue with some old SRAM brakes - it started with a rotor with a 'sticky' spot, and became a whole of frame vibration. What the cause was I have no idea as I sold the brakes and rotors and went Shimano new everything - and that solved the issue....
Posted : 29/07/2024 1:59 pm
Just came to to add bout facing mounts and ensuring spacers are allowing correct alignment
Posted : 29/07/2024 3:25 pm
thols2 and thols2 reacted
 FOG
As far as I can see everything is aligned properly and tightened. I might just have to give up and buy some Shimanos. Pity because the REs actually stop very well, it's just the teeth rattling vibrations
Posted : 29/07/2024 3:37 pm
