Venerable shoes - f...
Venerable shoes - for the bin?
6 Users
My trusty pair of AM901s have probably finally died. They're my winter shoes, a size too big so thicker and/or waterproof socks will fit in.
On installing some new cleats, I found that the central rib of the cleat slots has degraded and ripped out of the sole. I've had a think about this and I reckon the shoes are knackered. Even if I pop a little strip of hard plastic in to act as a kind of spacer between the cleat bolts, I still think the cleats are probably not biting into enough stuff that forms a fixed part of the sole. Plus those other contact points are also quite degraded by the look of them.
They're probably eight years old at a minimum and don't owe me anything. But they have stayed in one piece fantastically up until now and are extremely comfortable because of how softened they have become.
So, before, I chuck them out - does anyone have any amazing suggestions for keeping them running. Just asking on the off chance.
Posted : 14/03/2025 7:34 am
 Yak
You could try with new cleats, but they might rip out.. dunno. Might not though as the cleat nut is a bit larger than the whole slot area so it might have enough support...
I would try it on a short local ride.
Posted : 14/03/2025 7:42 am
Maybe try epoxy? With the cleats out loosely put the bolts back in and fill the area with 2-part epoxy but ensure it doesn't cover the bolts too much. Once it has set, remove the bolts and install cleats. Worth a try if you have the epoxy available.
Posted : 14/03/2025 7:45 am
Posted by: Oakwood
Sounds like they've served you well and it's time for a new pair.
Posted : 14/03/2025 7:51 am
Yes, this is basically the harsh truth. 🤣
Posted : 14/03/2025 9:17 am
Treat yourself to a new pair
Posted : 14/03/2025 9:26 am
Fill with bedding compost, pop in some primroses and stick them on the patio.
Posted : 14/03/2025 9:32 am
