Vee 2.6 Tyres - Sta...
[Closed] Vee 2.6 Tyres - Standard rims?
6 Users
Would I get away with these 27.5 x 2.6 tyres work on my 23mm rims?? Or would they just be rolling around all over the place?
https://www.planetx.co.uk/i/q/TYVEEFSEN/vee-tyre-co--flow-snap-enduro-tyre
Posted : 11/06/2020 9:29 pm
A bump mate as I'd like to know too.
Posted : 12/06/2020 3:59 pm
I'm running 2.5/2.6 tyres on i25 rims, no problems. Not Vee, but Vittoria and Michelin.
Both of them have quite burly sidewalls, which I think makes a big difference. Lighter weight tyres would probably roll more.
Posted : 13/06/2020 5:48 pm
Just because you can doesn't mean you should.
I'd stick to 2.4 max, based off my experience running 2.6in tyres on 23mm and 25mm rims previously.
Posted : 13/06/2020 7:28 pm
 Earl
My limited experence.
19mm rim on the front here.
Took off a 2.3 Purg Grid and mounted a 2.8 Michelin Wild AM. Made a huge difference for the better For a experiment I tried a 2.8 RocketRon with paper sidewalls. Terrible rolly and bouncy- as you would expect
Picked up some 30mm rims a few weeks back and sticking with the 2.8 Michelin. However if I was still on the 19mm, I'd still choose the 2.8 Michelin.
After much f**ing around with the pump - my optimums were:
19mm/Mich = 24psi
30mm/Mich = 18psi
Hope that helps.
Posted : 15/06/2020 10:12 am
I’ve got the 2.6x29 on a 30mm ID front rim. It’s great. However the wheel is not boost and there isn’t a lot of room inside the mudguard. I suppose in a narrower rim it would take up less space widthways
Posted : 15/06/2020 10:55 am
