vanilla R's to pike...
[Closed] vanilla R's to pike 426???
3 Users
Howdy, first post.
Got some stock 05 Vanilla R's on my marin rocky ridge and was looking to get something similar with lock out.
would i notice a big difference with 09 Rockshox pike 426's?
is lockout really worth it if i'm chasing time on red routes, or should i just stick to the R's
I'm using pro2 hubs at the momemnt so 20mm is not a problem,
Posted : 31/05/2009 5:35 pm
As a Rocky Ridge owner, with Pro2s, who has gone from 06 Vanillas to 08 Pike 426s, I feel qualified to answer this question:
YES, do it.
I wouldn't do it for time benefit though, the Pikes are a damn sight heavier than Vanillas. I'd do it for the bolt thru stiffness/security, the u-turn facility, the rebound adjustment and as you say, the lockout (with blow off) can make things a lot better on the smooth stuff.
Posted : 31/05/2009 6:14 pm
Just waiting to see the feed back on this, I have 2008/9 vans with 15mm axle on my FS and Air U turn revs QR on the hardtail.
Love the feel of the coil forks and am seriously considering changing the Revs for coil Pikes on the HT
Posted : 31/05/2009 6:20 pm
yea i noticed there was almost 1.5 pounds difference between the forks but i asumed that the lockout for smooth/climbing and with some lighter bar's & tyres i'd likely claim that time-weight back.
how did you find the different travel settings on the fork given that the RR has odd geometry?
D
Posted : 31/05/2009 6:37 pm
Ah well, thats the thing about u-turn, you play with it when you first get it, after a week or so you just set it to max! Really though, 140mm is great for bombing around the trails, 120-115mm sharpens things up nicely for more xc rides. I haven't been lower than that though, why would you! What do you mean by odd geometry btw?
Posted : 31/05/2009 7:27 pm
nothing, just the fact that its an aggressive ht designed for 130ish travel.
Posted : 31/05/2009 7:32 pm
Ah OK. As I said, stay in the 115-140mm range and its fine but definately noticable.
Posted : 01/06/2009 6:18 am
