Value of Titanium
[Closed] Value of Titanium
18 Users
how much is a broken titanium frame worth for just the titanium?
haven't googled right enough
Posted : 31/10/2014 8:40 am
hmm 11£/kg for ingot apparently
Posted : 31/10/2014 8:48 am
Is that for pure Ti? Are bike frames pure Ti or some alloy that no one else wants? Might change things if they are...
Posted : 31/10/2014 8:51 am
I remember Lynskey saying it was $150/lb going in and $15/lb going out.
Posted : 31/10/2014 8:52 am
no idea. presumably that's for pure, whatever that means
Posted : 31/10/2014 8:53 am
Stick it on eBay with a clear description and pics of the damage. Someone will buy it to try and repair it or for bits of tube for a project. You'll get more than scrap value.
Posted : 31/10/2014 8:55 am
what does that mean then brant? once they've done something to it it becomes less valuable as material?
Posted : 31/10/2014 8:57 am
Yes, AFAIK brand new tubes are much nicer to work with than ones that somebody else has already cut to specific sizes, put bends into, and welded bits onto.
Posted : 31/10/2014 8:59 am
i'm looking a short length of say seat stay, to cut slices of to make a couple of wedding rings.
be nice if it was formerly a bit of bike.
Posted : 31/10/2014 9:00 am
I'm off to China tomorrow. I can bring you some off cuts back.
Posted : 31/10/2014 9:03 am
My little bro picked up some billet pretty cheap on ebay a few years back and milled his own rings, and a set of darts which were pretty useless as they weighed about the same as paper aeroplanes 😆
Posted : 31/10/2014 9:07 am
@james most materials are worth less "post consumer", 10:1 ratio does seem a lot though
Posted : 31/10/2014 9:09 am
jamiesilo - Member
how i read it:
they buy Ti (tubes / billet) at $150 / lb
they sell the scrap/swarf at $15 / lb
at least, that's my take on it, and we get through a fair bit of Titanium (and other expensive metals - our swarf bins are valuable enough that we have to store them securely)
Posted : 31/10/2014 9:10 am
could you brant? that would be well smart! ideally a bit that tapers around 18mm internal diameter
give you a shout in a week or so can i?
or give you a reminder somehow while you're there? : )
aye ahwhiles/sunday jumper. i figured that out
Posted : 31/10/2014 9:13 am
how i read it:
+1
Quite an extreme ratio but titanium is very hard to process/reprocess so to make it worth it they will have to buy it cheap.
Your bike frame will be an alloy, probably be Ti-3Al-2.5V
Aerospace and medical applications normally use Ti-6Al-4V
3Al-2.5V is lower hardness and strength but less brittle and more ductile. It is also cheaper.
Posted : 31/10/2014 11:36 am
I remember one of the frame brands about 10 years ago saying you couldn't make seamless tubes in 6Al/4V, hence 3/2.5 was much more suitable. but Litespeed were making the Ultimate out of 6/4 at the time, so no idea!
Posted : 31/10/2014 3:09 pm
is brant brant brant back from china yet then?
do you need a reminder? any luck?
Posted : 05/11/2014 3:47 pm
He's been tweeting lots of pics of niche beer bottles. I think he'll be gone some time.
Posted : 05/11/2014 4:02 pm
Bought mine, for about £60 - I assume you have access to something to mill a nice bevelled edge on a random bit of tube?
They are a bit of a PITA actually - scratches sinks and other things merely by looking at them and asve to keep remembering to take it off before climbing, bike rides, DIY...
Posted : 05/11/2014 4:06 pm
[i]asve to keep remembering to take it off before climbing, bike rides, DIY... [/i]
is that wedding rings in general or Ti ones?
i have a very good pair of hands to work them and he also has a milling machine
Posted : 05/11/2014 4:33 pm
6/4 is so hard it trashes the dies used to form tubes (and other cutting tools). IIRC the 6/4 tubes Litespeed used were rolled and welded sheet (ie. not seamless); dont know about the Vortex but I had an Obed back in the day and their higher end MTB frames (Ocee, Tellico) had 6/4 downtubes made this way at least. The dropouts and BB shell on the Obed were 6/4 and waterjet-cut (and a pain for Q/Rs to get any purchase on, only Shimano skewers worked for me).
Posted : 05/11/2014 4:34 pm
Cracked titanium must be worth less then... 🙂
Posted : 05/11/2014 5:28 pm
£200ish/lb according to some. http://singletrackmag.com/forum/topic/whys-no-one-buying-my-frame
Posted : 05/11/2014 5:49 pm
I thought we'd agreed Ti was worth about 1/3rd RRP? 😉
EDIT: Damnit beaten to it!
Posted : 05/11/2014 5:50 pm
Ti rings are harder than gold so its a bugger to cut off in event of an accident. Worse case scenario can be losing a finger...which is my excuse for not wearing mine 😉
Posted : 05/11/2014 7:30 pm
I made my missus a Ti ring using a piece of Ti steerer tube. I cut a 5mm wide section, then cut a slot in it and bent it to shape around a piece of dowel about the same width as her finger removing the extra material. Filed the edges to put a bevel on it. I was thinking of polishing it and trying to anodise it as per Leni Fried but left it as it was.
Posted : 06/11/2014 9:43 am
