V-brake retro fitti...
[Closed] V-brake retro fitting to my balance bike
4 Users
So, thinking about it, I probably should have put some mounts on the frame I made to fit some brakes..
I've now got a set of Deore LX and am going to make some adaptors to fit over the swingarm to mount them on.
I remember from having V's that the mounting has 3 positions to locate the tensioner pin but was wondering if I would really need 3 as I can't check the angles.
Also, can I fit shorter length pads as the standard ones are too long and will foul on the tyre due to the small wheel size?
Steve
Posted : 27/01/2014 9:13 pm
I've never mounted v brakes other than in the middle hole. I think the other holes were more useful for cantis
Shorter pads will be fine
Posted : 27/01/2014 9:17 pm
 JoeG
You might want to read up on some of the canti brake stuff on sheldonbrown.com
[url= http://sheldonbrown.com/cantilever-fixture.html ]This[/url] and other stuff as well.
Posted : 28/01/2014 3:32 am
http://www.framebuilding.com/Bosses.htm
Posted : 28/01/2014 7:10 am
