Likely to end up in fire and death, however has anyone got any exoperience of using a non formual Cura 4 pad in their brakes? Royal mail have lost my parcel and i'm off to morzine in the morning with about 1mm left on the existing pads. Cura 4's seem like rocking horse poo...
ta
Currently using Galfer and Trickstuff pads in mine, no issues with either
sorry, meant a different pad design - i.e. shimano 4 pot or hopes - would they fit? I can't get any Cura 4 shapes anywhere at the moment..
Guess it’s just trying to find a pad the most similar shape to what you have. Not only to cover all the pistons / the right height for the caliper shape - but also with the hole for the retaining pin in the right place.
You might end up having the best option being to pickup some cheap brakes whilst out there to stick on the bike 🤷♂️
Just compared some Saint pads to some Cura4's buy placing the saint on top of the Cura.
Looks like they'll go in but may rattle a bit and the pad material sits a bit higher on the Saints when the holes are in line.
nice one Stu, that could be a pack up plan. Someone on Surrey Hills FB may have just come to the rescue!
AH, got it
Saint pads are quite a bit smaller than cura ones, I'd have thought
Surprisingly not much smaller.
BTW where are you getting your Trickstuff and Galfa pads from?
R2-Bike for Trickstuff, Galfer from Alltricks
OK cheers.
Was really looking for a UK supply as R2 want 12.5 Euro for shipping and Alltricks have a min order.
Life used to be so easy when we could order from all the European places easily.
https://dirthut.co.uk/galfer-brake-pads-for-formula-637-c.asp
bought from them before with no issues, infact I'll buy a couple more sets just know
Thanks for that dirthut link bruneep! I was literally just looking for Cura 4 pads as well. I like the standard formula organic ones but wow they do not last long at all, and I didn't want to keep bothering the Geometron guys for more. Ordered 2 pairs of the red Galfer ones.
On the saints - If the pad material goes above the edge of the disc then it won’t wear in that area and as the rest wears will ‘de-tune’ your braking ability.
ok to use just check regularly and file it down if necessary.
Cheers bruneep.
