Using a single spee...
[Closed] Using a single speed chanting with gears?
6 Users
 Aus
As above, hardtail, 10 speed...a RaceFace single speed ring up front. Will it be ok?
Posted : 13/03/2019 7:15 pm
If the ring is specifically designed for singlespeed, no. The teeth won't fit through a 10-speed chain.
Posted : 13/03/2019 7:18 pm
Gregorian or football?
Hare Krishna for the hi-viz win.
Posted : 13/03/2019 7:27 pm
The front ring just needs to be compatible with a 10 speed chain. It will retain the chain better than a ramped chainring. Definitely won't work if the chainring is for 1 1/8th BMX style chain.
Posted : 13/03/2019 7:29 pm
Ommmmmm...not sure
Posted : 13/03/2019 7:31 pm
I've had a quick look and I can't see a 1 1/18th raceface ring, they all seem to be 9-10-11 speed compatible, and mostly narrow-wide which would suggest they are not 1 1/8th
Posted : 13/03/2019 7:41 pm
 Aus
Cheers all...and chanting good.
Fitted it, seems fine so will give it a go...
Posted : 13/03/2019 8:14 pm
