Using 130 hubs in a...
[Closed] Using 130 hubs in a 135 spaced frame.
7 Users
Saving for my next bike and I am looking at the Cotic X (seen as it has rack mounts, lovely and steel, canti and disc bosses) for the versatility and future proofness of the bike. Currently my cross bike is a 130 spaced bike and I have 3 whole wheelsets and a separate rear wheel for the turbo so based on the amount of wheels I have I want them to be compatible.
I am planning on running it singlespeed for the time being anyway so would there be any problem in using some ally/steel spacers of 2.5mm either side and then adjusting the chain line accordingly for the spacers seen as re-dishing wouldn't be viable every time I changed the wheels from bike to bike.
Posted : 06/09/2013 11:17 am
I'd email Cy @ cotic and ask what he thinks.
With a steel frame it may be possible to have the stays reset to 130 rather than faffing about with spacers.
Posted : 06/09/2013 11:19 am
I've just put together an old alu Kinesis Crosslight, which has 135 spacing. Managed to simply use the QR to pull the frame in onto a 130 rear wheel - works fine.
I'd imagine a steel frame is even less of an issue...
Posted : 06/09/2013 11:21 am
Only gotcha would be that the mech could reach the largest cog on the block. It can probably cope with 2.5mm difference, so crack on.
Posted : 06/09/2013 11:24 am
I'd say so - look at how thick your dropouts are and how much of the axle they actually cover (i.e. how much of the axle protrudes beyond the locknuts - not a lot). Now remove 2,5mm from each end...
Unless you can replace the axles with longer ones (shouldn't be a problem on Shimano/other cup-and-cone bearing hubs) then you should be OK, otherwise I'd be looking at getting the frame spaced properly.
Posted : 06/09/2013 11:29 am
FWIW, My VN Amazon has 132.5mm dropouts so it can take either "standard". It's titanium and I don't know if that makes a difference to how flexible that makes it compared to steel.
Posted : 06/09/2013 11:39 am
Think the Roadrat is 132.5 so can go both ways?
But 130 in a 135 hole, or vice versa, might be pushing things a bit far.
If the dropout plates are sufficiently misaligned, then snapped axles is a side effect. Bin there dun that a few times on my olde worlde Peugeot road bike.
If I did either, I think I'd prefer wider wheel in a narrower hole and splay the dropouts a bit, rather than use tension of the skewer to hold it all together.
Posted : 06/09/2013 11:42 am
