uses for old innert...
[Closed] uses for old innertubes
42 Users
Innertubes (yes some people still use them) are great even after you have put enough patches on them to make them a slick tyre.
Here are a few bike related uses i found
Weather guards for headset and bb
Mud guard on fork
Replacement rubber for bike light
Spacer for handlebar mounts
Chain stay protector
Temporary fix for broken rebound damper
I recon we should get 101 uses betwee us?
Posted : 12/11/2013 5:13 am
Hanging stuff in garage
Cores removed to replace lost dowels in bed frame
Ice Axes & Ice Screw cover
Tie plants to canes in garden
Patch leaky hose in van
Retaining Straps on Bike rack (tie downs)
Dropper Post Protection Strip
Posted : 12/11/2013 5:23 am
Homemade fleshlight.
Posted : 12/11/2013 5:45 am
[url= http://www.beerbabe.co.uk/ ]lots of cool way to use an innertube here[/url]
Posted : 12/11/2013 6:03 am
Tree/fence decoration when you can't be bothered to take them home. 🙁
Posted : 12/11/2013 7:04 am
One has been blocking up a draft in my fireplace for nearly 10 years now. Big gap, about an inch wide. Inserted while flat, then a few breaths from the pump and its sealed the gaps just as well as any builder alternative.
Posted : 12/11/2013 9:21 am
Sidewall repair patches for tubeless tyres.
Crank arm protectors
Downtube/BB protection
Posted : 12/11/2013 9:31 am
Most of my old tubes from the last 10 years or so are gainfully employed in the pursuit of driving Mrs yunki nuts..
They are in the wardrobe, under the sink, hanging on coat hooks, draped over the bannister, under the stairs, in the boot of the car, behind the telly, on top of the bookcase, under the bed, behind the sofa, on top of the fridge, in the garden and hanging from the clothes airer..
She loves it
Posted : 12/11/2013 9:32 am
Thanks for the comment Trout. Used inner tubes have an endless number of uses.
Wallets, phone cases, frames packs - time to start dropping hints to Santa 😉
http://www.beerbabe.co.uk/ourshop/cat_740271-Bicycle-Tube-Products.html
Posted : 12/11/2013 7:36 pm
I use mine to protect my frame when bolting on the kids trailer (bracket/frame interface) and also I have the old chainstay protector option.
Posted : 12/11/2013 7:46 pm
[url=
I cut mine crossways and use them as elastic bands!
Dogsby
Posted : 12/11/2013 8:57 pm
Chainstay protector is a good one
Have another used to tie the cupboard where my bikes live shut to keep the kids out
Posted : 12/11/2013 9:03 pm
For a minute there I thought yunki was talking about bondage . . .but now ive re-read it I'm still not sure. . .
Posted : 12/11/2013 9:07 pm
rureadyboots, can you start a thread "what innertube for fleshlight?" please
Posted : 12/11/2013 9:11 pm
Protection for the bike rack.
Lashes/bungees for attaching bikes to bike rack kiwi style.
Posted : 12/11/2013 9:32 pm
i patched a hole in next doors oil tank with one to prevent kerosene pissing down the hill, also fixed a burst water pipe with one (and cable ties)
Posted : 12/11/2013 9:36 pm
From ray mears this one. They make excellent fire lighters for your stw log burner, a tiny bit burns for a good while.......
Posted : 12/11/2013 9:37 pm
I carefully cut out two squares, glued em together with double sided carpet tape and then cut out a nice circle big enough to go round under my crown race and wide enough to cover the lower headset cup
Hopefully keep the majority of muck and water out over the winter
Posted : 12/11/2013 9:41 pm
Cut the valves out and use them with a pump for removing the other piston in a brake caliper. or making one of those ghetto tubeless inflators.
What glue for sticking sheets of inner tube together? Will regular vulcanising solution work?
Posted : 12/11/2013 9:45 pm
 lerk
Cut out valve section, then wrap tightly around outdoor tap - tightarse pipe lagging!
Posted : 12/11/2013 9:52 pm
Bondage equipment in the dungeon ?
Gags, tying slaves up, blindfolds, whips, all with that lovely rubber smell.
It's a suggestion, not a recommendation BTW....
I used one as a lead for a dog I found... Dog happily returned to owner... Inner tube about three foot longer than by the time I got there...
Posted : 12/11/2013 9:56 pm
back in BMX days I used to cut valves off and add punctured tubed to inside of tyres, extra puncture protection!
Posted : 12/11/2013 9:58 pm
Inner tube jewelry FTW! 😀
http://urbanlacejewelry.com/
Posted : 12/11/2013 10:03 pm
They make a half decent temporary sling if you/a mate nadges an arm/collar bone etc. Also good for "towing" on a group if someone is really struggling and you need to get them home/to a coffee and cake shop pronto!
Posted : 12/11/2013 10:08 pm
^^^ +1 sling...able to walk 3 miles using it with a broken collar bone once...absolute godsend as I was on my own.
Posted : 12/11/2013 10:26 pm
Mostly as tree ties - for which they are very good
Although I think if you had as many as Yunki they would make an excellent spring to power a giant trebuchet :mrgreen:
Posted : 12/11/2013 10:51 pm
Regarding the gluing of tubes together I suppose it depends on the application
I just used carpet tape as I'd only wanted the extra thickness. If you want air tightness then I'd reckon vulcanising solution would work
I have one stretched over the moderator on my stalking rifle to stop it ringing when It brushes on foliage. I also use them as a grip surface for o ring mounted bike lights, rubber bands, tubeless patches, helmet mounts for torches, seatclamp mud seals, chain stay protector, cover for the head on my frame pump after seeing one that was so full of crap it no longer worked.
Posted : 13/11/2013 12:09 am
Always keep some in the toolbox. Had a leaking waste pipe under the sink. Cut a short length, slipped it on & leak gone. Lasted years.
Have some along the garage door to stop drafts.
Sit my roof bars on squares of it to stop them scratching the roof.
Posted : 13/11/2013 12:19 am
 iolo
They can be made into a rubber fetishists kinky knickers/bras/whatevever turns you on.
Posted : 13/11/2013 12:24 am
Tie your cables and hoses on with thin strips when youre out of zip ties
Oh and i once used one as in inflatable fake penis
Posted : 13/11/2013 12:25 am
- Holding tractor 3-point linkage arms together, stopping clatter.
- Toilet unblocking jet - cut in half, put down bog with gloved hand, blow hard. Avoid blowback.
- Catapult.
Posted : 13/11/2013 10:15 am
air intake anti-vibration device on mk4 Mondeos
Posted : 13/11/2013 10:46 am
Posted : 13/11/2013 11:08 am
Exhaust raspberry device
Posted : 13/11/2013 2:34 pm
Trebuchet spring.
Posted : 13/11/2013 11:41 pm
Washer for the outside tap.
Helmet/bar mount for a torch
Sheath. For a bow saw.
Posted : 14/11/2013 9:06 am
 xcgb
Chuck them in a tree?
Posted : 14/11/2013 9:31 am
If you run raceblades on your road bike, you can cut a couple of inches and slide them up the front forks prior to mounting. Helps prevent scratches.
Posted : 14/11/2013 11:11 am
Great for throwing in trees at trail centres
Posted : 14/11/2013 11:22 am
Lashing my canoe together. And this is not a bodge.
I have an outrigger canoe and use old innertubes to lash the float to the cross members and the cross members to the canoe. It does it really firmly but does have that little bit of give required when on the ocean and the boat is riding he waves. Like so....
Posted : 14/11/2013 12:05 pm
rOcKeTdOg - Shocking behavior, you should only ever do that with a 26 tube all 29er tubes should be saved to turn into -
http://www.beerbabe.co.uk/ourshop/prod_2460601-rocketdog-Wallet.html
@_rocketdog_ Wallets surely 😆
Posted : 14/11/2013 1:53 pm
I've used them as a fake oesphagus when making a 'Giant Digestive Tract' model for pupils. You can mimic peristalsis and everything.
Posted : 14/11/2013 2:28 pm
