Anyone kindly help and help me find 2 new rear bearings for my industry 9 rear hub please
I can’t seem to find any in the uk and mine are shot!
Just the main 2 hub bearings needed the freehub ones seem fine and smooth
The codes on them are
61804 LLU/LLB ABEC 5 CN
MR15307 LLU/LLB ABEC 5 CN
Any help massively appreciated 🙂
? There seems to be multiple links for both bearing types on the web.
61804 have the dimensions as 6804, just Abec 5 rather than 3 (built to finer tolerances).
The other one is harder to find though.
That first link is spot on as a review on the page says he used them in the front in i9 hubs too, and they use the same as one of the rear (which is actually the one that is most buggered on mine)
The 15307 one is a struggle find though
Have you tried shore lines? They import the I9 stuff and when I couldn’t find what I needed on the website I called them and I had what I needed in 24 hours. A lot of the stuff they have in stock is not shown on the website so defo worth giving them a call
Thanks guys - that one looks spot on, was hoping get them both from same place so I can fit them at once - will drop shorelines a message to tomoz and see if they have any in stock
Interesting are they good quality? I always thought enduro bearings were of a high standard? Don’t really want to be swapping them out a lot if not as good quality
Only seems to be the 15307 one in stock there? Unless I’m being blind
very average bearings with a big reputation.
Nah, it's all about the grading, and realistically, that's not hugely important when you get to ABEC 3 or 5, it's basically a couple of microns within the tolerances, and it's going on a bike hub, so not exactly huge amounts of issues from next to no changes in performance.
Just get the ABEC 3 off kinetic bearings, remember LLU/LLB are facing, so read up the colour that needs to be outward when fitting.
Looks like you're right there to be honest
With that news, the options are getting smaller, i fear you may be facing new bike time!
ha! thanks guys - ill take a look at the kinetic guys one, i need them as quick as possible - otherwise means no riding
cheers for the help 🙂
