Morning folks,
Quick question. If I upload a ride directly to strava is there a way to make Garmin Connect sync this ride also?
I know it works the other way around.
Thanks
Presuming you are using a Garmin device you can sync with Garmin connect and then get strava to pull it in automagically.
If you're using a device and going straight to Strava then the above should help.
Thanks both.
I'm uploading directly to Trainerroad (broken collarbone recently so no riding this year) and Strava pulls it directly from Trainerroad. I was hoping Garmin would pull it from Strava or Trainerroad automatically but it appears not.
I'm not using a Garmin device, just the Trainerroad app on my iPad. I normally just use Garmin Express.
The Trainerroad app is excellent btw!
TrainerRoad sync to Connect is apparently in the pipeline...
