Upgrading to a more...
[Closed] Upgrading to a more modern bike - what to expect? Hemlock -> Rocket
6 Users
I've decided to treat myself to a new (to me) bike, but having only ridden the old one for a few years I'm not sure what to expect to be different (if anything). I've not tried anything actually *new*, and given my pile of decent old 26" wheels and other 26" bikes, I'll not be going 650b any time soon.
Old: 2009 Hemlock, 2012 coil Lyirks up front and Fox rear shock with pro pedal (?? stiffens it up for climbing).
New: 2013/14 26" Rocket, 2015 dual rct3 Pikes up front and an x-fusion 02 rcx rear shock.
The wheels, brakes, drive etc aren't going to be much different. I hope the forks will be a bit lighter, but the weight of the frame and wheels isn't going to change much. Will the frame geometry change how it rides much? Rear wheel will be thru-axle rather than QR which in theory might be laterally stiffer, but I doubt I'll notice it that much.
I'm giving the Hemlock to my girlfriend, once I've swapped the Lyrics the something a bit lighter, but I'm slightly worried once the new shiny bike excitement wears off, there'll be no noticeable difference other than a hole in the bank account and my gf getting a free upgrade. Actually that latter point might make the most difference to general ride enjoyment, through her not getting shaken to bits on the old hardtail.
Posted : 19/12/2016 3:44 pm
2012 coil Lyirks up front and Fox rear shock.......2015 Pikes up front and an x-fusion rear shock.
Expect to be underwhelmed imho
Posted : 19/12/2016 3:45 pm
Hmm, I thought as much. Both frames use 200 x 57 rear shocks, so I could in theory swap them and the forks over and essentially just upgrade my frame. Makes me wonder if it's worth bothering at all though, but I have an itch which ought to be scratched...
Posted : 19/12/2016 3:53 pm
It'll be different but learn to embrace the difference instead of hankering after your old bike.
I would have probably tried a few different ones before buying though.
Posted : 19/12/2016 4:17 pm
I've not bought it yet, but realistically I'm not going to be able to demo a secondhand bike for a whole day before buying it, and riding around a car park isn't going to tell me much. The market isn't huge for 26" bikes now, and I'm a bit of a Cotic fanboy (can you tell?). Considered a Yeti ASR-5, which I have tried out, but warranty and carbon worries put me off.
Posted : 19/12/2016 4:28 pm
Pikes are great and there's nowt wrong with x-fusion shocks.
I have one on my 27.5 Rocket and it works well enough. Pikes on the front too.
Why not look at a bike which takes both sizes of wheel such as a Banshee?
I ran 650b Pikes on my bike long before I had 650b wheels. Didn't notice any ill effects.
Posted : 19/12/2016 4:34 pm
this might help, Cy Turner talking about the 2011 Rocket.
Do your mates not have different / newer bikes to you that you could try?
Posted : 19/12/2016 4:35 pm
Other than the Yeti ASR 5, which I have tried briefly , no - I don't have a huge bunch of riding mates*, and the few I do ride with are two frames sizes different to me. Short arsed loner... 🙄
*it's 4, including the girlfriend! Tend to ride on my tod quite often.
Video is useful, ta.
Posted : 19/12/2016 4:42 pm
The missus has a Hemlock I have a 26" Rocket...
I've had coil Lyrics and now run Pikes. I've had mine custom tuned and there's now not much in it performance wise, but they are a fair chunk lighter than the Lyrics.
Is your Hemlock a 1 1/8" headtube or a 1.5" one? You can Rocketerise your Hemlock by sticking a Slackset in if it's the latter - where the whole Rocket geo came from.
Yes they do feel different - the Rocket is a bit lower and a lot longer and slacker. It's properly confidence inspiring on the steep & twisty stuff. It's handy uphill too - I'm just sat in exactly the right place on the bike, no fannying with travel adjust forks etc, you can just winch up stuff (although I have to say I think traction on loose ground was slightly better when I used a granny ring). The suspension feel is generally "involving" rather than sofa-like, but then you hit something big and the bike just makes it go away... The Rocket pumps and pops better too, IMO. (more progressive suspension rate)
I can't comment too much on stiffness as I'm a weedy 140lb-er, but to me the Rocket feels noticeably stiffer than my old Intense Uzzi VP and a whole bucketload better than herself's Hemlock - although that's been built for a non-aggressive mile-muncher rider with really light wheels and it's still got the old flexy chainstays on.
Posted : 19/12/2016 5:05 pm
