Upgrading an old bi...
[Closed] Upgrading an old bike
10 Users
I am looking to resurrect my wife's nearly 20 year old Cannondale Jekyll for my 13 year old daughter.
I have a few old bits kicking around (carbon bars / good 26 inch wheels / hope brakes) but not sure what to do with the gears or what fork and dropped options there are.
Any suggestions?
Mark
Posted : 23/08/2020 8:25 am
https://photos.app.goo.gl/bqCe9q6mWwnnb8iK7
Image -
old bike
A link?
Why can I not make images work!
Posted : 23/08/2020 8:27 am
It's not worth spending a lot of money on an old bike, so my approach would be to put the money into things you can transfer to a newer frame.
There aren't a lot of options for new 1 1/8" forks anymore, maybe Suntour.
If it were me, I would go with 2x9 with steel 22-36 Deore rings and 11-36 cassette.
What's the seatpost size. BrandX dropper is the obvious choice. They do an externally routed 105 mm drop post in 27.2 mm and 150 mm in 30.8 mm.
Posted : 23/08/2020 8:46 am
There aren’t a lot of options for new 1 1/8″ forks anymore, maybe Suntour.
I’d be amazed if that headtube wouldn’t take a tapered steerer, with a new headset.
Posted : 23/08/2020 8:51 am
I would save that bike. Its not like its a piece of junk. 13 year olds may well change their minds and also getting a new bike is pretty awkward now.
Try and get the bike going with what you have. No need to change anything.
I have stripped a couple of bikes and about to put stuff on the classifieds. Have some Fox forks 1 1/8, Deore brakes, XT shifters that would make 10 speed and a chain and cassette , which will fit if you need anything. Let me know 🙂
Posted : 23/08/2020 8:54 am
Yes the head tube is about 2" outside diameter so ahead of it's time!
Posted : 23/08/2020 9:02 am
Yes, that would change everything. First thing to investigate.
Posted : 23/08/2020 9:03 am
In the name of future proofing, a 659b fork will run a 26" wheel no problem. What wrong with the current fork?
Posted : 23/08/2020 9:15 am
I’d give it a good service and leave as is. It’s not as if it was a piece of junk when you bought it. If she takes to mountain biking, consider something better next time. Might update the tyres.
Posted : 23/08/2020 9:33 am
I've just done something similar with the wife's inbred for my 13 year old daughter.
1x using a narrow wide was the biggest game changer. It's 32t on the front mated to a sunrace 42t cassette.
Posted : 23/08/2020 10:15 am
I can't offer much advice re forks. If it were my bike, I'd just leave them, unless they no longer work, in which case a second hand pair of Rock Shox Rebas or similar air fork would be where I'd look.
I'd get rid of the front gears and just go 1x, cant imagine a 13 year old would get much use out of the big ring. Fit something small enough like a 30t, and you'd likely be okay with the current cassette.
A shorter stem and lower bars might be needed to get the fit right.
Posted : 23/08/2020 11:50 am
It looks just fine. Clean, straighten, bleed brakes, service fork and ride? Or is the drivetrain mashed?
Posted : 23/08/2020 12:22 pm
What would be the best way of going 1x with an old style Shimano freehub?
Posted : 23/08/2020 12:23 pm
Didn’t old Cannondale’s have 1.5” headsets to make them Lefty compatible?
Posted : 23/08/2020 12:24 pm
Singlespeed kit 😎
Why not first try removing the outer and granny rings (replace outer with bashguard) and see if the cassette had a useful enough range for intended use?
Posted : 23/08/2020 12:36 pm
You can get everything up to 12 speed on the older style hubs (SRAM and sunrace make cassettes for it.)
Posted : 23/08/2020 12:56 pm
