Upgrade from Rebas ...
[Closed] Upgrade from Rebas to ... ?
5 Users
Am finding my 120mm Solo Air Rebas at bit too linear. Is it worth looking at something else (if so what?) or am I just being a tart?
Usage is XC-trail, anything from SDW through to trail centres and BPW reds, on a steel 29er HT.
Can go up to 140mm if weight penalty is manageable.
(thx)
Posted : 04/10/2014 7:33 pm
Revelations should tickle your taste buds,
Posted : 04/10/2014 7:36 pm
Sick a widget in the air chamber.That'll ramp 'em up a bit
Posted : 04/10/2014 7:53 pm
Yes, it's easy to make forks ramp up more, by adding something (oil if there's no dedicated part) to the air spring to reduce its volume. Sadly it's rather hard to make them more linear (like my old 32s need!)
Posted : 04/10/2014 8:04 pm
You cannot add oil to solo air forks to change the air volume.
Posted : 04/10/2014 8:29 pm
Is that because of the transfer port to charge the negative chamber?
Posted : 04/10/2014 9:28 pm
