Under helmet cyclin...
Under helmet cycling caps - for pumpkin sized heads
9 Users
16 Reactions
I’ve been after some under helmet cycling caps for some time. Everything I’ve bought or tried has been on the tiny side. I’ve a massive gourd of a head 62-63cm.
Almost all caps are “one size fits all”. But they don’t. At the large end of the spectrum is a Madison cap I have, it just about fits, although it could still do with being a touch larger. I’ve tried Cyclogy, Stolen Goat, Restrap (actually measured as 52cm), even Fat Lad At The Back (measured at 58cm).
Anyone found anything bigger?
Posted : 25/11/2024 7:41 pm
Fellow Mekon here, I've got a couple of Van Rysel caps from Decathlon that are a nice fit on me, could be worth you trying?
https://www.decathlon.co.uk/p/roadr-520-cycling-cap/_/R-p-304955
Posted : 25/11/2024 7:59 pm
bax_burner, bigblackshed, bigblackshed and 1 people reacted
I've had a couple of Galibier caps that came up larger than "normal".
Posted : 25/11/2024 8:05 pm
Might be a bit spendy but I was looking for a cap with a short peak and bought one from this guy. Notably he does them sized to fit so you can specify the size of your pumpkin.
https://www.etsy.com/uk/shop/TurificHandmade
No doubt others available. Unfortunately I lost the first one and the replacement's material isn't quite as nice feeling, but still a very nice hat.
Posted : 25/11/2024 8:10 pm
I have a Galibier cap which at the time came in 2 sizes. Not sure if they still do that?
Posted : 25/11/2024 8:13 pm
Interesting to know, as this subject comes up quite regularly
Posted : 25/11/2024 8:41 pm
Thanks people.
The Galibier caps look to be one size. I’ve ordered a couple of the Van Rysel ones from Decathlon. I’ll see how they fit.
Posted : 27/11/2024 6:22 pm
cyclistm and cyclistm reacted
This any use?
https://images.app.goo.gl/Dp39UbAimjE66Nvq9
Posted : 27/11/2024 6:33 pm
I said pumpkin SIZED, not pumpkin STYLE.
Rollyeyed emoji.
Posted : 27/11/2024 10:13 pm
Campagnolo Egyptian cotton are one size fits all but have a huge amount of give in them. Spendy at £30 each, but a small peak and good coverage means they are excellent.
Posted : 27/11/2024 10:40 pm
I have a similar sized head.
Walz make an XXL to order (extra $2.50) which claims to be for 63cm. I've never pulled the trigger because of the cost, but they look like a quality bit of kit.
https://www.walzcaps.com/collections/cycling
Posted : 28/11/2024 7:50 am
The Decathlon Van Rysel caps turned up today. Spot on fit. Really nice lightweight material, so will make good three season caps.
Those Walz caps look very nice.
Posted : 28/11/2024 4:50 pm
Alpkit do one that comes in large:
Strada Cap Organic Cotton Cycling Cap
I also struggle with one size fits all headwear. and this one is pretty good.
Which reminds me I haven't seen it for a while... must go and dig it out.
Posted : 28/11/2024 9:02 pm
The Van Rysel caps are down to £8.99 at the mo. Just bought 2 to stock up and help justify the still reasonable P&P.
Thanks for the thread
Posted : 28/11/2024 9:48 pm
