Uber bargain Rocksh...
[Closed] Uber bargain Rockshox Revelation 29er forks
21 Users
OEM but still a steal!! £350 for RCT3 or £280 for the RL and remember 3% Quico cashback 😮
RCT3 Revelation 140 Dual Air 20mm Maxle (can be internally reduced from 140mm in 10mm increments to 100mm)
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=94599 [/url]
RC Revelation 130mm 20mm Maxle (again pretty sure can be internally travel adjusted)
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=94595 [/url]
Posted : 16/01/2013 9:33 pm
Significant difference between RL and RCT3?
Posted : 16/01/2013 9:40 pm
RCT3 damper is fapping ace and you get dual flow rebound, RL is the standard MoCo.
Posted : 16/01/2013 9:41 pm
Worth the difference?
EDIT: Having only used MoCo and never had any issues with it I'm tempted to just go with the RLs
Posted : 16/01/2013 9:42 pm
RCT3 is worth every penny over standard motion control.IMO of course.
Posted : 16/01/2013 9:43 pm
I would say so.
I really can't decide 🙁
Posted : 16/01/2013 9:44 pm
Buy the RCT3, they are much better, there mind made up!!
BTW these are OEM so no pump or fancy RS box or spare seal kit but who cares at that price.
Posted : 16/01/2013 9:47 pm
Already got a pump and seal kits are cheap, so not worried about that. Cheers Doug, Think I've decided.
Posted : 16/01/2013 9:49 pm
bigdugsbaws - didn't you have a rev on your Sultan that you thought was a bit of a 'noodle'?
What's the dual air like, if it's two travel settings anyone know what the shorter one is? Any reliability issues? IIRC didn't some RS dual postion forks have horrendous reliabilty problems?
I was hanging on for the X Fusion Trace but the trails are freezing up and I'm sorely tempted by these!
Posted : 16/01/2013 9:50 pm
I did have a Rev on the Sultan and whilst its nowhere near as stiff as a Lyrik or 36 I never found it noodly. (I have a Rev on Both of my bikes currently)
Posted : 16/01/2013 9:55 pm
Did the one on your Sultan have the 'power bulge' or is that a new development?
Posted : 16/01/2013 9:57 pm
Ordered the cheaper set, I'm on too tight a budget to justify the extra, and don't think I'd notice enough of a difference. Thankyou for this PSA though, best I've seen in a while.
Posted : 16/01/2013 10:01 pm
Yes it had the power bulges, a 2012 model same as these. Its reduced to 120mm and on my Fireline Evo now if you look at the pics on that thread.
Posted : 16/01/2013 10:02 pm
Whats it going on Sam?
Posted : 16/01/2013 10:03 pm
No idea yet. Long term probably a Horsethief, short term maybe a hardtail of some sort, cue what cheap 130mm 29er Hardtail frame threads. Will have hope hoops, wish Arch EX were available as hoops 🙁
Posted : 16/01/2013 10:05 pm
Is the Dual Position Air an external travel adjust? Sorry for all the questions but I'm thinking if I order them now I might get them for the weekend!
Posted : 16/01/2013 10:06 pm
 nuke
[i]Is the Dual Position Air an external travel adjust? [/i]
Yes, 30mm raise/drop at the click of a switch (and push of the bars)...neither of those forks have it, internal adjust only
Posted : 16/01/2013 10:08 pm
Dual Air just means seperate positive and negative air chambers, Dual Position is externally adjustable. If you're not talking about the forks above then ignore me.
Posted : 16/01/2013 10:09 pm
Dual air is internal adjust
Dual position air is external 140mm to 110mm but cant be reduced down internally. The travel adjust is a bit like ETA on Zocchi forks, intended for climbing
Posted : 16/01/2013 10:11 pm
The RCT3 details on CRC list 'dual position air' and 'external travel adjustment'. Sounds like these have them or does anyone know if this a CRC typo?
Posted : 16/01/2013 10:26 pm
Its just a generic description of the Rev range nicked from the RS website, I got a set just after xmas and they are deffo dual air.
Posted : 16/01/2013 10:41 pm
Cool, ta. Reviews of the dual position aren't too clever anyway, seem to be compromised like the Fox Talas so think I'm going to order a pair. Thanks for the PSA!
Posted : 16/01/2013 10:49 pm
Ordered! And a spanking new Bel Air to complete the build. Excited now
Posted : 16/01/2013 11:12 pm
I've got some brand new Revelation Dual Position 140 20mm maxle 29er forks, bought from On One last year but never fitted and now unwanted as I bought a complete bike rather than build up a frame as I intended.
they're boxed, uncut steerer never even out of the box £220 posted.
Posted : 16/01/2013 11:27 pm
The RCT3 revs I have are markedly more composed than the black box RLT Ti revs I had before.
At that price they're a total bargain.
How do they go on the Sultan SO? Do you miss the travel adjust at all?
Posted : 16/01/2013 11:29 pm
 timc
crazybaboon ygm
Posted : 16/01/2013 11:36 pm
fairly sure this is wrong, they all have same dual flow rebound on 2012 afaik. someone like Loco will confirm..
Posted : 17/01/2013 12:56 pm
well spotted!
Had a pair of the RL's delivered yesterday that I paid £329 for on Monday.
Have ordered the RLT's and will be sending the RL's back now.
They'll go nicely on my new Titus Fileline frame.
Posted : 17/01/2013 1:06 pm
crazybaboon, ygm unless they've been sold already
Posted : 17/01/2013 1:21 pm
 Andy
Dual position 110-140 revs on a Sultan here. Works really well with the 140mm forks on the flats and downs and the 110 is great for twisty flat stuff and climbing
Posted : 17/01/2013 1:27 pm
I missed the travel adjust for about three rides before I remembered to hunker down a bit. It's not like the DW squats on climbs like some bikes do.
I don't miss feeling like I have to twiddle a lever every time the ground goes up, just because its there!
Posted : 17/01/2013 8:02 pm
Did RS ever cure the clunking on their u-turn forks...
Will the dual position ones go the same way ?
Best forks I ever rode were bog standard dual air revs.
Posted : 17/01/2013 8:54 pm
My Coil U-turn Pikes were silent, is it just their air forks?
Posted : 18/01/2013 7:40 pm
 GEDA
They are even cheaper now. I got some for 289 - cash back!
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=94599 ]Cheaper revs[/url]
Posted : 20/02/2013 11:59 am
And still 347 sets in stock. I wonder how low the price will go 🙂
Posted : 20/02/2013 12:07 pm
 GEDA
Now which frame to go with them. Looking at the Titus fireline or scandal. Like the idea of the ti but the rear tyre clearance looks like a whiff of mud will lead to much unhappiness.
Posted : 20/02/2013 12:10 pm
Blimey at that price I'm tempted to pick up a set for some unimagined future project.
Edit: GEDA, have a Scandal frame waiting on some cheap 29er SIDs. Surely 140 revs too tall? Now that fireline...
Posted : 20/02/2013 12:16 pm
Argh, too many days left until payday!
Posted : 20/02/2013 12:17 pm
@rse, just paid £349. Send back and order cheaper methinks 🙂
Where does it say how many in stock? I can't see it anywhere.
Posted : 20/02/2013 12:21 pm
They are (apparently) internally adjustable down to 130 or 120mm and (again apparently) the spacers to do this come in the box. I'm also thinking that these are too good a deal to resist as I'm bound to want to build a 29er one day. Just wish they where white rather than black 😳
But what if they pop up in the private sale next month even cheaper? Well I guess I could live with that. A good price is a good price regardless of whether somebody else gets an even better one.
Posted : 20/02/2013 12:22 pm
cooie, to find out how many items they have in stock you stick it in your basket, go to the checkout, change the quantity to some large number (say 1,000) then click the update button. It will tell you that you can't have 1,000 but will then show how many are left.
Just remember to put the quantity back to what you want before you finish checking out 🙂
Posted : 20/02/2013 12:24 pm
😀 Cheers
Posted : 20/02/2013 12:27 pm
FWIW I couldnt resist and bought a set of the cheaper RL Revelations too.
It has dual flow rebound and Motion Control DNA; to be honest it feels as good as the RCT3 !!! 😀
P.S. They are internally adjustable for travel but you get no spacers
Posted : 20/02/2013 12:28 pm
What are the chances of asking if they'll refund the difference,rather than sending back and reordering at cheaper price? Anyone tried this before?
Posted : 20/02/2013 12:30 pm
 GEDA
I was thinking of spacing them down. I already have some spacers.
Posted : 20/02/2013 12:31 pm
Not sure about this, but aren't the spacers in the fork anyway? I thought you just moved them from one side of the piston to the other, but I've never done this, so could be totally wrong.
Posted : 20/02/2013 12:32 pm
Cooie: I bought some of the RLs at £330 in December, saw they dropped to £280 before I fit them, emailed and got a £50 voucher.
Posted : 20/02/2013 12:55 pm
Cheers giqles, will email them.
Posted : 20/02/2013 1:01 pm
are these 32mm or 34mm stanchions?
Posted : 20/02/2013 1:07 pm
32 stanchion. 130 mm has 1 * 10 mm spacer inside, the 140 has no spacers inside but comes with them.
You can also reduce travel the lazy way by increasing negative air 😉
Posted : 20/02/2013 1:33 pm
BDB are they burly enough for 29er AM duties?
I'd be worried about them being a bit bendy at 140MM travel
Posted : 20/02/2013 1:45 pm
I think I will have to get a set of these at this price for my planed tallboy lt or sb95 purchase later this year.
Is the only difference on these that they dont have a pump or spare seals? evrything else is the same?
Posted : 20/02/2013 4:48 pm
