Tyre Width on a roa...
[Closed] Tyre Width on a road rim - Can I go skinnier than recommended
4 Users
Just had a rear wheel replaced by the LBS, basically its a Mavic Kyserium elite which is the same as was on it before, only issue is that its a 2016 model which has replaced my 2015 version.
Slight cosmetic difference but the issue I see is that the 2016 model is 2mm wider, and recommends running 25-32mm tyres. I've always run 23mm front and rear and can't really be bothered buying a new set of tyres.
So will a 23mm tyre work, or will I die? Whats the worst that will happen?
ta
Posted : 06/10/2015 5:38 pm
Yes, eventually, blowing off the rim on a 100 kph alpine descent, leading to a faster question 2 answer
Posted : 06/10/2015 5:40 pm
23's fine.
Posted : 06/10/2015 5:43 pm
Have you seen the table near the bottom of this page?
http://www.sheldonbrown.com/tire-sizing.html
Posted : 06/10/2015 7:20 pm
