Tyre wall repair
[Closed] Tyre wall repair
6 Users
Hi
Anyone know of a good repair for a 10mm split in a side wall? Tyre still has otherwise 100's miles of use.
Posted : 30/09/2010 8:53 pm
sew it with dental floss
my make used a pasties wrapper to get round climax works for 5 miles but wouldn't recommend for long term
Posted : 30/09/2010 8:57 pm
I patched mine up with a cutting of flat plastic(food packaging) and taped it in with duck tape, that worked well enough though the tyres were worn out so only needed last a few rides.
There are products that you glue in place made of thicker rubber.
By the time i've typed this someone should've of posted a link up or gave it's name.
Posted : 30/09/2010 8:58 pm
Glue a patch of innertube to the inside. Halfords sell large sheets of patch as well
You might need to sew it up - but 10mm maybe not
If you do sew it up sailmakers needle and waxed dental floss is good ( its strong and pulls thru the tyre easily)
Posted : 30/09/2010 8:59 pm
+1 on the dental floss!
Worked for me on a certain bike ride around Kielder 🙂
Posted : 30/09/2010 9:02 pm
Stitch with a fine fishing line (I would think that would be more durable than floss. You'll need a darning needle. Then superglue a tough patch on the inside to protect your tube. Superglue in the cut from the outside too. That should do the trick.
Posted : 30/09/2010 9:03 pm
