On my rigid Fatty I've swapped my front tyre from a 120 tpi for a 60tpi.
It's no longer feels as good at soaking up bumps.
Am I imagining it, will it soften with wear?
I've measured the tyre and it's the same width but not quite as tall.
Posted : 13/04/2016 10:48 am
Higher TPI tyre carcasses are more flexible, plus they tend to be thinner (less rubber) which means lower rolling-resistance - even more noticeable at lower pressure because the tyre flexes more. Tubeless too makes a difference because of the energy losses between the inner tube and the tyre carcass
Posted : 13/04/2016 10:54 am
