I'm sure I saw this on the news page but may have hallucinated it. Anyone know what it is that I'm looking for?
ta
Andy
[url= http://www.ebay.co.uk/itm/TYRE-RIM-BEAD-LUBRICANT-LIQUID-SOAP-LUBE-MOTORCYCLE-MOTOCROSS-MOTORBIKE-QUAD-/320921434860?pt=UK_Motorcycle_Parts&hash=item4ab8687aec ]This stuff[/url] was mentioned on here a while ago - is this what you were thinking of..?
Can't open that link from work. Is it a grey or brown tin?
It was Rotherham Tyres liquid bead lubricant on eBay that I linked to - neither grey nor brown!
We have some at EBC - schwalbe I think.
here we go
http://www.edinburghbicycle.com/products/schwalbe-easy-fit-special-assembly-tyre-liquid
Found it:
[url= http://singletrackmag.com/wp-content/uploads/2014/01/IMG_2366-800x600.jp g" target="_blank">http://singletrackmag.com/wp-content/uploads/2014/01/IMG_2366-800x600.jp g"/> [/img][/url]
The Schwalbe stuff is a damn sight cheaper though.
I use GT85
I use muckoff or value washing up liquid.
I use something like this.
http://www.ebay.co.uk/itm/REMA-TIP-TOP-TYRE-MOUNTING-PASTE-TYRE-SOAP-5KG-AND-PASTE-BRUSH-/181303960600
I originally bought it years ago for fitting Land Rover tyres.
If you are only using it for bicycle tyres, a £14 bucket like that will last several generations.
I've been wondering if any of the 'patent' options are worth springing for.
Until late last year I mounted tyres dry, then discovered 1+4ish washing up liquid which I can't believe I managed without...
£2.99 and awesome. Huuuuuuge tube. Will last a lifetime.
http://www.on-one.co.uk/i/q/TOBYSLG-1000/nrg_bike_gp1_sliding_grease___1000g
Last time I fitted tubeless tyres (last month) I just wet the rim strip with sealant and the tyre beads popped in place OK. Soap is a bit slippier I guess, but sealant is possible. You might as well try.
