im running 2.35 rims just wondering if a 2.5 tyre would fit these rims? my mates all use the maxxis wet screams and was interested if i could use them, one of them seems to think id have no problem with it so just wanted to make sure it would fit ? anyone running 2.35 with a 2.5 tyre thx
What do you mean by 2.35 rims? If you mean, rims came with 2.35" tyres on, fitting 2.5" tyres will be fine. Some '2.5"' tyres are narrower than other '2.35"' tyres.
I doubt your rims are 2.35 but 2.5s will be fine.
Wet screams are designed for proper shitty conditions. Good for that but draggy and squirmy the rest of the time. Cutting them down makes a good intermediate tyre.
2.35 rims
Rims are measured in mm.. So a mavic 717 rim is 17mm wide.
But if you've run a 2.35 fine, you will probably be fine with a 2.5, if your frame and fork can take it. Never heard any horror stories from people running too big tyres.
I've seen a frame worn through by a too big tyre.
