Tyre pressures. How...
[Closed] Tyre pressures. How low do you go?
39 Users
Being radical I've dropped from my 1990s 40 psi all round to 35 front and 30 rear.
I'm running 2.1 ground controls tubeless and weigh 12 stone in my pants.
Is there a magic formula to working out optimum pressures?
Posted : 04/06/2017 7:51 am
You've heard the old saying for torquing bolts? "until it snaps and back it off half a turn".
I think it's similar due to the number of variables.
15st rider.
2.35" reinforced sidewall tyres - tubeless.
30mm internal rims.
160/150 travel bike.
Ridden reasonably quickly down peak district rocky stuff.
23f/26r
Posted : 04/06/2017 7:57 am
 Yak
Weight in lbs/7 = psi.
Then adjust +/- a bit (mostly -) to suit front and rear, tyre choice etc. Only a starting point, but it's about right for me.
Posted : 04/06/2017 8:02 am
Yak's formula gives me about 22, which is about where I am. (22-ish front, anywhere from 25-28-ish rear)
Posted : 04/06/2017 8:04 am
13 front, 15 rear on 29+ mulefoot 50mm rims. I'm 12st 4lb. Keep meaning to go lower, but have visions of tubeless gloop flying out of sidewalls. Yaks formula is way out for me, all although would be spot on for standard tyres.
Posted : 04/06/2017 8:06 am
Will give 25 a go tomorrow.
Posted : 04/06/2017 8:09 am
I'm 12 st 6lbs and I ride with about 20psi front and rear. If I'm at a downhill day on a rocky course, I go up to 25-30. But for my local trails which are rooty, rocky and steep (and slower speed), if I run over 20psi then I lose too much grip.
I'd like to run at 17-18psi, but below 20, I start to feel the rim touching too much. And my tyre start to squirm.
I've tried running st 30-40psi, but I just feels like I'm continually bouncing about from rock to rock.
Posted : 04/06/2017 8:11 am
Drop it until the tyres start rolling on corners then add a bit.
Posted : 04/06/2017 8:12 am
About 6 psi front and rear...
Yak's formula is much easier in English - twice your weight in stone! Bit higher at the back.
Posted : 04/06/2017 8:17 am
Yaks formula +/- 5psi covers my range depending on front/rear, tubes/tubeless.
Twice my weight in stone, bit lower at the front on tubeless.
Posted : 04/06/2017 8:20 am
Get tyre squirm below ~22psi (Chunky monkey on Crests) so that's the limiting factor. I then tune the rear so they have similarish grip levels, although this changes with conditions so I tend to leave it at ~26 psi as this means the rear normally slides first.
I find when bikepacking I need 29/35psi, and that's with only 9-11kg of kit added to the bike/me, but without it the bike is squirmy and near impossible to ride
Posted : 04/06/2017 8:21 am
Interesting article albeit roadbased here
[Url] https://cyclingtips.com/2017/05/what-is-the-optimal-tyre-pressure-2/ [/url]
If you read down the comments a guy links to a googledocs spreadsheet. [Url] https://docs.google.com/spreadsheets/d/1W_qsdZPfxDoaQ5A94mfTaVdIOrmHtjCQ_zAtHXf6t00/edit?usp=drivesdk [/url]
i couldn't work out the logic or formulas...what i did find interesting if the methodology is correct is how big an impact front / rear weighting has
I did try the calcs for my gravel bike based on a guess on weighting and the answers worked well for me..10psi lower on rear and 20 lower on front on what i thought were quite low pressures
Posted : 04/06/2017 8:42 am
 Yak
Good point! I got it from the stans website years ago when I first went tubeless. All in lbs over there.
Posted : 04/06/2017 8:45 am
Yak formula gives me 28.
I habitually run 25 front, 27 rear (tubeless, Spesh grid sidewalls, UK riding from local woods to rocky Lakes).
Will usually go to about 27/30 for rocks or events where I don't want to puncture ('Ard Rock, etc.).
Posted : 04/06/2017 8:48 am
All in all, quite a consistent approach here.
I like the weight in stone times two as a rough starting point and it pretty much mirrors what I have.
Is it the same pressure for tubeless or tubed though?
Posted : 04/06/2017 8:54 am
That formula actually works for me and by chance is what I'm running.
Comes out as 31psi.
I use 30 in the front and a bit more in the back up to 35.
Much lower than 30 on the front and I get snake bites.
Posted : 04/06/2017 9:04 am
I'm sure I read something once that did it by tyre "sag" but I can't remember how much the tyre was supposed to compress under rider weight.
Posted : 04/06/2017 9:07 am
Yak's formula says 29psi for me.
29x2.3 minions, hard/slippy ground (Staunton) yesterday and was running 17f/19r. As the ground dries up will up the pressures to keep the tyres from squirming in the turns and with higher speeds, bottoming the rims.
Posted : 04/06/2017 9:11 am
That formula is a bit suspect. It will depend on tyre volume.
A 4" fat tyre will need a much lower pressure than a 700c 23mm road tyre.
Posted : 04/06/2017 9:13 am
 Yak
Definitely will be lower for bigger volume tyres. Imo it's ok at around 2.25 width.
Posted : 04/06/2017 9:15 am
colournoise - Member
Don't actually use a pressure gauge too often though.
Think I picked it up on here, but the fruit squeeze test works for me. Orange on the front, apple on the back.
Posted : 04/06/2017 9:20 am
Depends on the tyres, trail and condition, UST racing ralph on a wet penmachno about 18 (fantastic levels of grip for a fast tyre), TR racing ralphs on the local hard baked loam about 35.
Posted : 04/06/2017 9:24 am
The formula is from Stans, as a starting point for tubeless MTB tyres, not CX bikes, not fat bikes.
Posted : 04/06/2017 9:50 am
I think most of us took it as such.
Posted : 04/06/2017 10:05 am
70 Kg, 2.3 Maxxis single ply. 17 PSI front, 20 rear. Run that everywhere
Posted : 04/06/2017 10:13 am
Dry condition for normal trail riding I run 29 front 31 rear. Don't really mess about with the rear but in wet condition drop about 2psi in the front.
Posted : 04/06/2017 10:32 am
I was playing withh tyre pressure the other day, no formulaic approach, just trying different things, I ended up with 24psi up front (any lower and it washed out really easy) and 20psi at the rear.
why does everyone run higher pressure at the back?
I'm riding hardtail BTW
Posted : 04/06/2017 11:37 am
I weigh about 75kg + kit, and ride in the Lakes on 29" HT and a 29" rigid.
23mm internal rims- fr 2.4" 24psi rr 2.25" 26.5psi
40mm internal rim- fr 3" 11psi
Posted : 04/06/2017 11:53 am
Because on steep climbs, nearly all the weight is on the back tyre and you also tend to smash the rear wheel over stuff more than the front so you need a bit more pressure in the back to prevent damaging rims. I weigh about 80 kg with gear and generally run 25 front and 30 rear on 2.35 x 26 tyres FWIW. I could run them 5 psi lower, but I prefer to have a margin for leaks, etc.
Posted : 04/06/2017 11:56 am
Seated pedalling on the flat the weight distribution is about 30/70 F/R, standing on the flat it's about 40/60. And when riding the back tyre suffers the bigger loads most of the time, squirming first in berms, rim striking first through rock gardens, etc.
Posted : 04/06/2017 12:03 pm
8 psi front 10 rear
Posted : 04/06/2017 5:28 pm
But it is a very good point, the actual difference in volume between say a 29x2.4" and a 26x2.1" is pretty substantial, and both sit within what could be considered "normal" MTB tyre sizes these days... I reckon the formula needs updating to take account of wheel diameter and tyre width.
Posted : 04/06/2017 8:08 pm
Except carcass stiffness is equally important and rim width isn't far behind. And then there's riding style and rider strength. It's a starting point, no more no less.
If it feels bouncy decrease, if it feels squirmy increase.
Posted : 04/06/2017 8:15 pm
 momo
Have stuck to the Stans formula for years and ended up with 31/34 F/R. @.3(ish) tyres on 25mm rims. Now running 35mm rims on 2 bikes, 2.5/2.4WT Maxxis on the FS, 3" spesh purgatory grid on the B+ rigid. The FS is set to 21/24 the B+ 13/15.
Wide rim and tyre combo is very forgiving of low pressures, even for a fatty like me!
Posted : 04/06/2017 8:17 pm
26/28 F/R for me with EXO/Grid/SG tyres. Tubeless on 30m DT Swiss rims.
Anything less I find the tyre squirms when cornering hard & I get punctures.
Posted : 04/06/2017 8:39 pm
19 front 22 rear on 2.35 tyres on 29er HT and 26er FS.
Posted : 04/06/2017 9:19 pm
13f/16r Maxxis 29x2.25 when racing my Yeti hard tail 59kg
Posted : 04/06/2017 9:29 pm
If you're still running 1990's tyre sizes stick with 1990's pressures. Tubeless will allow slightly lower pressure without pinch flats, but the main difference is huge tyres. I run 40psi on my 26x2.1, 30psi on my 27.5x2.3, 18psi on 27.5x2.8 and 13psi on my 26x4.8.
I'm a few PSI higher than is trendy these days but...
[list]
[*]I hate squirm on corners[/*]
[*]I'm 92kg[/*]
[*]I ride fast[/*]
[*]I very rarely crash[/*]
[*]I very rarely puncture[/*]
[/list]
your mileage may vary, but it must be your choice based on your riding.
Posted : 05/06/2017 6:54 am
I normally run 20psi front and rear. although I had a blowout cornering hard at 23mph at BikePark Wales last weekend resulting in a pretty hard crash.
This was on the second of 2 days riding, and having then checked the rear tyre (which was at 10psi), I think they had lost some pressure from the hard riding over roots and rocks the day before.
Moral of the story, check your tyre pressures every day!
Posted : 05/06/2017 7:31 am
I usually run about 21 Psi front and between 22-26 Psi in the rear depending on how rocky it is. I run a magic Mary super gravity front and a HR2 single ply rear both tubeless.
Posted : 05/06/2017 7:57 am
I run Specialized grid carcass tyres tubeless on both my bikes, but I struggle to find a happy medium with tyre pressures. I do default to 35/40psi (F/R), but for technical riding that's way too high. I don't like that feeling when the rear tyre squirms under lateral load, it feels as though my rear suspension is kaput.
Having said that, I don't usually notice the difference with 30/35psi, but I might try dropping lower and will see how it goes.
Posted : 05/06/2017 8:55 am
What are people using to measure pressure? Recently bought the Topeak D2 gauge as I thought now that I'm running tubeless it'd be good to be able to accurately repeat pressures from pump to pump. Thought I was running around 30F/34R; turns out my preferred pressure is 21F/24R! That's Maxxis EXO 2.35 on 30mm internal rims, 160/145 FS, 14st (kitted up) rider.
Posted : 07/06/2017 10:23 pm
Topeak gauge here as well. Track pump gauges are mostly useless for measuring pressures.
Posted : 08/06/2017 6:55 am
25 front 28 rear for me, well that's what my gauge says. The actual number is irrelevant I guess as its what feels right. I like a stiffer side wall to help reduce squirm/roll as running high pressure feels pretty horrid and unpredictable to me.
Posted : 08/06/2017 7:06 am
idiotdogbrain - Member
POSTED 8 HOURS AGO #
I've just picked up the Topeak D2 as well. Used it for the first time last night and was a bit surprised. I weigh about 90kg kitted up with a full 3l pack etc. I always just used my Joe Blow track pump and stuck 30psi in previously. The D2 measured this at 20psi - I was actually going to start a thread this morning about the accuracy of the D2. My tyres feel quite firm and surprised they only read at 20psi.
So what are peoples thought on accuracy?
Posted : 08/06/2017 7:19 am
having ridden my FS for the past few weeks (Anthem with 650B carbon rims, Nobby Nic 2.25) and 24/27 I was on the Soul 26'er last night, with 2.3 Purg's and Mavic 719's. I found rear at 27 was banging on the roots a lot, so a wee pump up to 30 and it was much better. I am just over 12 stone.
Posted : 08/06/2017 7:29 am
I've a couple of pressure meters (different manufacturers) and they are reasonably consistent between them and also consistently lower than the gauge on the track pump.
So long as the gauge is consistent over time I'd just inflate to whatever pressure you are happy with and use that, the actual number isn't that important.
Posted : 08/06/2017 7:59 am
Rarely measure them just squeeze/prod
For me thin tyres work over a wide range of pressures
The fat tyres are more sensitive to temperature
Posted : 08/06/2017 8:06 am
