Tyre levers of choi...
Tyre levers of choice?
17 Users
1 Reactions
Broke my old faithful Pedro's levers today, what are your choice of levers?
Posted : 03/04/2023 6:15 pm
I use park tool metal ones and they've never failed. They only come out when there's no other option. A bit of electrical tape around them softens them up a bit if you're worried about scratches.
Posted : 03/04/2023 6:24 pm
Cushcore Bead dropper, if you want a proper burley one for getting really awkward tyres on.
Posted : 03/04/2023 6:29 pm
Decathlon's own are pretty good. Pedro's for the commute as I sometimes have Schwalbe tyres on the bike.
Posted : 03/04/2023 6:35 pm
 cp
https://www.decathlon.co.uk/p/pack-of-3-tyre-levers-yellow/_/R-p-120
Been using these for years when things get tricky on tight beads
Posted : 03/04/2023 6:56 pm
My favourite are these ones....
Posted : 03/04/2023 7:07 pm
Cushcore bead dropper is good if using tough tyres / inserts.
Otherwise I’ve got a few lurking about - pair of cheapie blue plastic park ones generally do ok. I think the chunky yellow plastic ones in the garage may have come free with mbuk a few years back. I’m not precious as long as they aren’t thin flimsy things.
Posted : 03/04/2023 7:18 pm
I rarely is them, but have a pair of Birzman green ones that work when I need them. On the bike the oneup multi tool has one built in.
Posted : 03/04/2023 8:43 pm
I got the yellow freebies with a copy of MBUK years ago, still going strong and outlasted 3 bikes and numerous tyres
Posted : 03/04/2023 9:01 pm
Broke my old faithful Pedro’s levers today, what are your choice of levers?
More Pedro's?
Also, the Cushcore Bead Dropper as recommended above if you're doing tough tyres and / or ones with inserts.. it does work remarkably well!
Posted : 03/04/2023 9:15 pm
dc1988 reacted
I always use the basic blue Park levers or the cheap Pedros ones.
I’m also a fan of the cheap flat Continental levers.
Posted : 03/04/2023 9:19 pm
Lezyne Power Levers. The single-ended ones, and normal size not XL for most jobs. They're nothing clever, they just have a really good hook which means it needs less tyre slack to get a tyre on and off.. Basically every big sturdy lever I've ever used, has only had to be big and sturdy because it has a less good hook and so needs to create more slack. But these little guys are great.
I've broken a few over the years- they're not indestructible- but they cost peanuts and they don't hurt your rim, they're imo just definitely better than Park or Pedros.
Posted : 04/04/2023 1:10 am
I bought my Topeak Shuttle levers when I worked at a LBS about 14-15 years ago. Still going strong now
Posted : 04/04/2023 4:57 am
Pretty positive you can claim warranty on them.
Posted : 04/04/2023 6:42 am
Park metal x2
Posted : 04/04/2023 7:01 am
Topeak Shuttle here too and a BBB Easy Tyre jack for the least amount of fitting fuss at home
Posted : 04/04/2023 8:00 am
Thw schwalbe with clips for holding the bead on, game changer for fitting an insert
Posted : 04/04/2023 8:03 am
