"Twisted"...
[Closed] "Twisted" Larsen
10 Users
I stuck a new Larsen on there, the casing seems to be a bit twisted. I have checked the rim and its straight as a die, as are the markings around the edge of the bead. Its a new folder, can I expect it to stretch itself out a bit or is it a faulty tyre?
Normally I'd just ride it and see what happens but the first proper ride it gets will be Kielder on Saturday.
Posted : 02/09/2010 11:22 am
Is it seated properly?
i've had a tyre before (Halo Choir Master) that was seated correctly but despite my best efforts I could not get rid of the wobble it had. Put it down to a fault with the manuf, but the tyre still performed as it should. is this what yours is doing?
Posted : 02/09/2010 11:27 am
Sometimes you just need to pump it up to 60 psi to make sure it's *really* seated.
(Then let it back down to sensible pressure. Dont forget that bit.)
Posted : 02/09/2010 11:33 am
Its tubeless on a Crest rim, its holding air no problem and the bead is evenly seated all the way round, I'm pretty sure its either a faulty tyre or it just needs to stretch out a bit, I'm hoping the latter.
Posted : 02/09/2010 11:35 am
 D0NK
you positive the bead is seated uniformly [i]all the way round[/i]? UST could be not seated correctly and still hold air. Only time I've seen this is from the bead not being seated or a damaged tyre casing causing a bulge.
Posted : 02/09/2010 12:00 pm
Its definitely seated, all the way round, both sides. The little cross-hatched bit of the bead between the sidewall and the rim is an even depth. When I unfolded it last night I thought it looked a bit mis-shapen at some of the folds, but it had 50 psi in it with a tube overnight to stretch it out and it went up alright with a track pump.
Posted : 02/09/2010 12:15 pm
 sv
Had this on a Flow/High Roller combo - some washing up liquid and a bit of extra pressure sorted it.
i don't think it will stretch out. if its noticable by eye then it wont be ok.
kendas used to be quite bad for this.
Posted : 02/09/2010 12:18 pm
Stan's solution all over the flowerbeds! 😆
It blew off, its back on with 40 psi in it but its all over the place, I think the tyre is f*cked.
Posted : 02/09/2010 12:57 pm
I blew a High Roller off a Stan's 355 rim by going over 50 with it
I don't think those rims are quite designed for that sort of treatment
When mine went it wrecked the tyre & put the wheel out of true
Posted : 02/09/2010 1:07 pm
Yep the wheel itself has a wobble now, LBS time.
Posted : 02/09/2010 1:10 pm
...Yikes.
Okay, errrm, I take that suggestion back 😳
My Bonty rims always need that process to seat the tyre (currently Maxxis, run tubeless but non-UST) but I've never had one blow off the rim.
Posted : 02/09/2010 1:30 pm
I have two non tubeless Larsen TTs hung up in my garage that both have wobbly tread.
Posted : 02/09/2010 1:37 pm
I've got a Nobby Nic that's always had a kink in it.
Posted : 02/09/2010 1:51 pm
I swore I'd never get another Larsen, the last one I had ripped badly on a pretty tame section of trail. I really like them as a rear tyre but I think they're a wee bit fragile in the sidewalls. Obviously my ham-fistedness was a contributing factor in this case.
Posted : 02/09/2010 2:13 pm
