Twist grip stiff
[Closed] Twist grip stiff
4 Users
The twist grip on my son's bike has got very stiff, to the point where he can not really use it. Changed cable and improved things a bit but still hard work. Is this just how these things age or can I fix this somehow?
Posted : 30/03/2011 5:13 pm
Squirt through with GT85, did you change the cable outer too? Checked cable line and mch is moving freely etc?
Posted : 30/03/2011 5:19 pm
GT85, check, mech check, cable line check
left the old outer in place after blasting with GT85, so perhaps thats it
Posted : 30/03/2011 5:52 pm
Sram used to recommend not using anything other than a silicone based grease(Jonnisnot was their official brand), other types of lube can sometimes cause the plastics to swell and bind. +1 for new cable outers too.
Posted : 30/03/2011 5:56 pm
is everything lined up ok (ie not pulling round tight corners etc)
an old motorbike tip was to get cable end to highpoint (with inner still inside), make a plasticine (etc)funnel at top of outer cable, fill with light oil etc and leave for it to soak down entire cable overnight
