Tweed valley path, ...
[Closed] Tweed valley path, Inners - glentress. Open yet?
6 Users
Does anyone know if this route is open yet?
[url= http://singletrackmag.com/wp-content/uploads/2011/03/peebles-gets-more-off-road-trails/ ]inners to glentress[/url]
Taking my partner to glentress for the first time tomorrow and planning on doing the green and blue but could do with a another option
Posted : 02/11/2012 11:26 am
Not sure but if not take the old railway line by the river and then out the back of Cardrona.
Posted : 02/11/2012 11:34 am
Nope, the Glentress - Inners link isn't open, that will be around March(ish) 2013. The cycle path between Peebles and GT however is open, it's a good smooth surface to cycle on.
If you want to cycle to inners use the route Mark mentioned above. Cross directly over the road at the Glentress Hotel, cycle down the path that runs alongside the field, at the end turn left down the old railway line (now a fireroad track) to Cardrona Village. Turn right at the roundabout and then left and go along the back road to Inners (3 miles approx). You can short cut a wee bit through Traquiar House, saves a few mins.
Posted : 02/11/2012 12:39 pm
Great cheers!!!!
Posted : 02/11/2012 12:46 pm
 hels
Last time I went past, the bit past the golf course was being dug up, and was pretty much impassable, but they may have sorted that by now.
Posted : 02/11/2012 12:55 pm
I was along that way on Saturday, the bit by the golf course has been sanatised from just below the ruined castle at GT to Cardrona village.
Posted : 02/11/2012 12:59 pm
The path between Inners to Howford crossing is finished do if you know where that is you can cycle from the Cardrona part on the main road for a short section before joining it.Most should be finished fairly soon. They won't surface the bit between Howford crossing and the new bridge apparently as farmers use that bit.
The bridge won't be put in until early spring (End Feb time?)because of some wildlife issue (Fishing?) so you won't be able to ride the whole thing 'till then but should be a great facility 😀
Posted : 02/11/2012 1:45 pm
