I'm looking at some tubeless Contis will they work with tubes? Is there any difference in a tubeless beads?
Ta
They'll be absolutely fine, though, might end up being heavier/more expensive than the regular ones.
confirm they work just fine.
A tubeless 2.4 RQ with tubes is pretty much a DH tire
Note.. DT EX1750's with DT rim strips and tubeless RQ casing is a very tight fit. I would not want to be doing a trail side tube swap with that combo!
Tubeless contis bead with a floor pump with rim strips.. very easy intro into tubless and they will hold air like no-ones business.
Give it a shot tubeless.. very robust setup ime
