Tubeless tyre repai...
[Closed] Tubeless tyre repair patches
5 Users
Put two holes in a brand new maxxis DD agrressor at bike park wales last week. The larger hole (1cm slit) wouldn’t seal with a plug so I’ve now got a tube in
ive seen an mbr vid where he advises super glueing the hole then sealing with a tyre patch on the inside of the tyre to set up tubeless again
would a tube patch work or do i need to get some specific tyre patches? They look pretty similar online but happy to buy some specific tyre patches if it makes a difference
cheers
james
Posted : 04/06/2018 1:28 pm
As above, just replenished mine, they are cheaper if you buy in bulk
Posted : 04/06/2018 1:40 pm
I've used standard tyre patches on a hole of a similar size. My first attempt failed, but second time round I scrubbed the area to be patched with steel wool, and left the patch clamped in place for a while.. The patch was applied using the normal rubber glue. It's worked fine for about 4 months...
Posted : 04/06/2018 1:52 pm
Ok cheers, I’ll get some ordered.
the patch attaches to the inside of the tyre with the plug poking out thru the hole then you trim off the excess?
james
Posted : 04/06/2018 1:54 pm
Yes thats how it works
Posted : 04/06/2018 2:10 pm
Used the previously mentioned ebay link on a brand new Minion SS after I pinched it on its first day in Italy. Has been on the rim for a couple of weeks now and really pleased with how well its done. Would defo recommend them to rescue a knackered tubeless tyre. I imagine it won't last forever this way as my hole is on the sidewall but every day it lasts is a blessing!
Posted : 04/06/2018 3:46 pm
