tubeless set up pro...
[Closed] tubeless set up problems.....help
5 Users
 ton
never run tubeless, fancied a go.
so today i tried to set my wheels up.
chronicle 29 x 3 folding tyres, stans tubeless kit, and alex md40 rims, which i have be assured work with tubeless.
got everything in place, tried to pump up tyres with a track pump.
not a chance.
help.
Posted : 06/08/2018 7:01 pm
More tape/ swearing
Posted : 06/08/2018 7:19 pm
Compressor / airshot?
Posted : 06/08/2018 7:21 pm
 PJay
Probably this, but you could try seating the tyre using a tube, then break the seating on one side and remove the tube followed by the 'tyre lever trick' of lifting the free bead with a tyre lever which you then run horizontally around the rim to pull the bead up onto the bead bead - then pump like mad with the valve core removed.
Posted : 06/08/2018 7:29 pm
Washing up liquid around the sides. Take the core out of the valve.
IIf that fails put a tube in, inflate. Remove tube but leave one side seated. Inflate. Don't bother about the sealant until you have got the tyre inflated. Once you've inflated add sealant through the valve.
If you are struggling I've got a airshot you can borrow.
Posted : 06/08/2018 7:37 pm
