Tubeless rim tape w...
[Closed] Tubeless rim tape width crossrise?
4 Users
Does any one know what tubeless rim tape width would work best for some mavic cross ride wheels (26") ? Thanks
Posted : 25/01/2019 9:55 am
Just measure the internal width of the rim.
Posted : 25/01/2019 10:37 am
Ok having never used tubeless before and the rim is a curved u section is it the total curved surface or just from inner edge to inner edge across the top to be measured? Thanks
Posted : 25/01/2019 11:27 am
Internal width (edge to edge) and add on 4-5mm
Posted : 25/01/2019 11:39 am
As long as most of the internal width is covered you're good to go.
Posted : 25/01/2019 11:44 am
I always go a little wider with the tape than the internal width like scotroutes says above. In principle you should only need to cover the spoke bed, but the wider coverage is reliable IME.
Posted : 25/01/2019 12:16 pm
