After a few months of loving tubeless again, my latex has sealed my valve. No only did it seal it so well that I could bearly get any air IN, it also jammed partly open and allowed a slow leak so I was half-way round my night ride when the tyre became unusable. Combined with a lack of pump able to over-come the re-sealed valve it left me wheelying, manualing and eventually walking most of the way home (a couple of miles). GRRRR.
Does no-one else get their valves gummed up?
Been running tubeless for about 5 years and never had this problem.
Not really, no
Over time there's build up but nothing that totally jams the valve
If it was leaking slightly beforehand, I guess it could have caused a quicker & more pronounced build up
What's the other valve like?
I think it might have been the leaking that caused the gumming. I sometimes get a bit of build up on a valve but nothing to write home about.
Latex just peels off, surely you can unscrew it and peel the gunk out?
Hard to tell if the valve had been leaking, no signs of gum outside the valve and of course the pressure had dropped but I'm not sure if that was just due to permiation of the rubber/seal round the rim or the valve. Maybe it was the valve. That would make sense. I'll whip it out and clean it up tonight and see how I get on again!
anotherdeadhero - I'm not saying fixing it isn't easy, I'm just saying it seems to happen a lot and fixing it requires another trip to the compressor to re-seat the bead.
My track pump got some sealant in the attachment gubbins and now only operates at around 50% efficiency. No problem with valves sealing up tho.
Yeah I remove the valves and un-gum them from time to time
This does occasionally happen. As has been said, just dismantle the valve and de-gum.
Spraying some silicon spray into the vale when its clean can help prevent the built up for a while.
Oooh I like the spray idea, interesting.
Its not a permanent solution, but it helps some.
When you lose the air to remove the core, do the beads of your tyres come unseated?
That doesn't happen on my flows - and just inflate them again after with a track pump.
Always carry a co2 adaptor/cartridge and a plier-based multi-tool.
One to blast, the second to remove if blocked.
And buy a compressor for home.
