tubeless nightmare
[Closed] tubeless nightmare
15 Users
I'm after some ideas as I'm having a nightmare getting my new conti baron to seal using stans notubes sealant and a mavic crosstrail UST rim. So far I've tried
soapy water on the tire and a track pump = no joy.
same again with an 8 bar compressor + lots of swearing = still no joy
The used rubber queen i fitted on the rear mavic rim only needed a track pump and a quick shake to seal. so Ive currently put a tube in the baron with 40psi to see if the tire just needed a couple of days on the rim to seat in.
cheers gaz
Posted : 10/02/2014 9:38 pm
[url= http://singletrackmag.com/forum/topic/ghetto-tubeless-inflator-total-cost-9p ]thread here[/url]home build a pop bottle thingy...
Posted : 10/02/2014 9:40 pm
i'll give it a try thanks.
Posted : 10/02/2014 9:50 pm
 Kato
I was having loads of trouble with a Bonty TLR tyre even with a compressor. Found taking the core out the valve helped seat the bead in the end
Posted : 10/02/2014 9:58 pm
As Kato said, I have had problems even with a compressor until I took the valve core out. I cut the internal sealing bit out to leave the external part of the core (if that makes sense...?), screwed it back in so I could attached the pump and everything has gone up fine since then. The valve core restricts the airflow and does not allow enough oomph to get the tyre moving on the bead.
The only alternative to this is a CO2 cartridge I think.
Iain.
Posted : 10/02/2014 10:07 pm
 si66
I've got barons on crossmaxes and the first time I seated them they were well tricky
I did it by using just sealant, lying the wheel down then pumping like mad with a track pump
As the bottom bead started to seal turn the wheel over & the latex can seal the other bead
It took about 20 minutes to get both up
Now they've been on the rims a whole they're dead easy and pop up no bother
Good luck!
Posted : 10/02/2014 10:17 pm
I'll give it a go again tomorrow without the valve core and see how I get on. If that fails its DIY bottle pressure thingy. I'll let you know the out come.
Posted : 10/02/2014 10:29 pm
 chip
Co2 inflator and some soapy water in a squirty bottle works for me.
I have been using 12g capsules as have loads knocking about, they seat 3/4 of the tyre then finish off with track pump.
Although I have just ordered 30 16g capsules from tyreinflators for £20 plus £5 postage.
They should last me a while, also carry one when out on the road on the commuter for when I get a puncture in undesirable surroundings where I feel a bit of a soft target late at night with my bike upside down, otherwise I just use the mini pump.
Posted : 10/02/2014 10:47 pm
tomorrow go in all guns blazing.
the tyre will be pre-stretched from having a tube, but also remove the valve core and use plenty of strong washing up soln everywhere and then stick it on the compressor till its banged/popped properly onto the rim.
try to let it deflate slowly so the tyre doesnt jump part off the rim
put the sealant in via the valve (coreless) after the first inflation then assemble the valve and inflate again 40+ psi and do that shakey thing or go for a quick ride.
Posted : 10/02/2014 10:50 pm
[url= http://singletrackmag.com/forum/topic/ghetto-tubeless-inflator-mk-vii ]This is my solution[/url]
TBH, it's rare tyres don't seat with my track pump but [s]I'm lazy[/s] furious pump action seems to hurt my dodgy back. Well that's my excuse & I'm sticking to it.....
Posted : 10/02/2014 11:25 pm
http://singletrackmag.com/forum/topic/30-secs-of-your-time-please-tubeless-survey
Fair bit of discussion on the above thread. Amazed so many people don't think there's a real demand for home mechanics bit of kit, that doesn't include coke bottles or a great big compressor.
Posted : 10/02/2014 11:59 pm
[img] http://s836.photobucket.com/user/garyanderson1981/media/Mobile%20Uploads/2014-02/A87E4263-F857-4C69-BFEB-E715484D13DF_zpscxpiwasz.jpg.html ][IMG] http://i836.photobucket.com/albums/zz287/garyanderson1981/Mobile%20Uploads/2014-02/A87E4263-F857-4C69-BFEB-E715484D13DF_zpscxpiwasz.jp g" target="_blank">http://s836.photobucket.com/user/garyanderson1981/media/Mobile%20Uploads/2014-02/A87E4263-F857-4C69-BFEB-E715484D13DF_zpscxpiwasz.jpg.html ][IMG] http://i836.photobucket.com/albums/zz287/garyanderson1981/Mobile%20Uploads/2014-02/A87E4263-F857-4C69-BFEB-E715484D13DF_zpscxpiwasz.jp g"/> [/IMG][/URL][/img]
Job done. Thanks for the input.
Posted : 11/02/2014 9:31 am
Read lots about needing a large volume of high pressure to pop the bead on to the rim/into place...the question i have, as someone that's yet to try this, is it obvious when a tyre is popped into place on the bead?
Will i know when it's in place?
As only ever run with tubes before never noticed anything 'popping' into place...so hopefully its obvious when you try?
cheers
Posted : 11/02/2014 11:14 am
You'll hear a very audible bang when the bead seats, very obvious.
Posted : 11/02/2014 11:16 am
Great - thanks for that. Also from what i read it can be possible to seat the bead using a tube as well.
So worth trying that and leaving inflated with tube overnight first...
I'll be giving it a go tomorrow night and then starting another inevitable tale of tubeless woe thread shortly after...
cheers
Posted : 11/02/2014 11:22 am
Conti tyres are generally a total arse to seal when new.
With particularly stubborn tyres the best tip I can give is to stick a tube in at highish pressure(40PSI plus) and leave them overnight then go back, carefully remove the tube whilst disturbing the other side as little as possible to try and leave the bead seated. put your valve and tyre-spaff in and pump it up.
The tube will push them out and form them into shape that makes them much more willing to pop on.
The good news is that once they've been mounted once they're much easier to work with, it's just brand new ones that are a real pain.
Posted : 11/02/2014 12:00 pm
Conti recommend this:
Posted : 11/02/2014 12:09 pm
Hatter i found that, my old RQ fitted with not one problem but the new Baron was a total pain. had to do the "bottle" trick to get it to seat not even my works 75Kw 7.2 bar compressor could get it to seat :D. I also think fitting a tube over night helped too as the tire had a much better shape when fitting it this morning.
Posted : 11/02/2014 12:23 pm
+1 for the washing up liquid - apply both sides of the tyre and lay flat, inflate quick as you can witha track pump and it normally seals 1st time - no need for compressor or pop bottle in my experience. BTW, I use Schwalbe and they seat even after being stretched
Posted : 13/02/2014 4:07 pm
You need to do it again, your valve/logos aren't lined up
Posted : 13/02/2014 4:11 pm
