Tubeless Bead Punct...
[Closed] Tubeless Bead Puncture
6 Users
So a year back I didn't quite as 'nicely' as I do now. As a result I have a couple of tubeless high rollers with pinch punctures on the bead itself/very close to. The usual tubeless plugs don't work and I can't see patches working either. Any ideas on fixing these for further tubeless use?
Posted : 30/09/2010 9:12 pm
snakebite on a tubeless? i thought the reason niche riders went tubeless was to stop this happening
Mods remove this post before we have a internet riot on our hands
Posted : 30/09/2010 9:17 pm
 br
Superglue and build up the bead with patches, or just give away to the luddites to use with a tube.
Posted : 30/09/2010 9:19 pm
The velox tubeless patch kits work fine for repairing these punctures. Just cut one of the patches in half so you have a straight edge, clean and dry the tyre up and stick it on. Worked fine for me a couple of times.
Posted : 01/10/2010 6:24 am
normal patches + sealant works pretty well. If I'm feeling particularly paranoid I'll stick a patch on the outside too.
Posted : 01/10/2010 8:11 am
Ok cheers, I'll try those. The plug method prevent the bead from correctly seating in the rim so hopefully building up with patches will help!
Posted : 01/10/2010 9:42 am
Use car/motorbike/tractor patches. They're a lot bigger and thicker. I've used them for repairing a damaged sidewall.
Most motor vehicles are tubeless nowadays, so try an agricultural or motorbike shop as they are more likely to stock patches.
Posted : 01/10/2010 9:59 am
