Hi - I'm looking for some new cranks (2x10) and whether these are worth the cash? CRC have them on sale at the mo.
I have a Chris King BB so would I need a stepped converter to fit them (GXP)?
I liked the look of some of the e-thriteen and raceface cranks too so value your input!
Thanks
Define good? They're heavier than XTRs whilst costing more, having crap chainring longevity, and a dire BB.
Converter required for King BB yes.
And they get tatty as hell in no time at all.........
Well 'good' would be not being heavy for the price, lasting and having an OK BB!
So I'll steer clear as that's pretty much what I've read.. Ta.
I'd go XT or XTR over Sram any day, Shimano cranks just work.
gxp is a load of rubbish
Not sure I can change the type of BB my frame accepts?
DO yourself a favour and use XT.
Merlins got them on sale bit cheaper i think..?
My X0 cranks are 2 years old, had heli tape from new, and still in great nick!
Heavier than XTR - 15g - Wow!! Suggest you cut the cuffs of your socks if you think that matters!
Crap BB? Mine run on a Hope ceramic BB with GXP converter - wonderful after 2 muddy years!!
Mine were £200 from CRC - how much are XTR??
By the way - love them to bits, and still on the original chainrings
I've always been an XTR man but am running these on my Epic and love them - crazy price and the included Ceramic BB is holding up well so far (certainly better than the XTR one).
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=75445 ]FSA K Force Light 386[/url]
I think they look great too with the 386 chainrings.
I stuck with my old XTRs, no advantage at all to the X0s and some disadvantages. You can remove the central spider thing and fit a bling ring for 1x10 which saves a tiny amount of weight, though.
If they are GXP - why do they need a converter? Is that to try and get you to buy a Sram BB?
or is it that my BB isnt 'GXP' ?!
No, hope bb's, and CK I think are Shimano HT compatible. The converter allows a SRAM GXP crank ie the X0 to run on them. Works well too, IMHO.
There is a Hope video on their website.
I have X0 cos I wanted to run a 28 and 30t ring so I have a bling ring. Saves a load of weight. I would have continued to run my beloved xtr but really needed to go below 32t front. I got mine for £200 and tbh, so far and pretty happy, stiff, spin smoothly, weigh naff all, 630g with the BB. I'll swop to a king BB when the existing gxp dies.
88mm BCD on the doubles? Or 64 on the triple/trail double?
Run XO here too with a 30T bling ring and loving it. Got mine off here for approx £100!!
gp
the simple answer to your question is that Truvativ make possibly the worst bearings in the world.
Hence the reason why other companies make bearings (or full BB cups and bearings) that can be used as an upgrade / improvement on the original Truvativ bearings.
For an explanation of what is involved in changing the bearings:
I liked mine and was sad to see them go in my recent cull. I never had an issue with them. The comparison with XTR might stack up at RRP, but at actual selling price the comparison should be more with XT. Oh, and in my opinion they look the nuts.
Njee, I have the trail so I could have fitted a 28/30t in the granny position but then I couldn't run the chain device and the clutch mech isnt enough 🙁
I've had an x0 chainset for the past 9months, I've had no problems at all. They have been stiff and light - what more can you want?
As said previously, they arent that much heavier than XTR (but are avalible cheaper) and as for chainings you can pick them up for around 50quid a pair (less than a pair of xtr) if you know where to shop.
The standard gxp BB is pretty gash, but the hope and chris king versions are very good so when the standard one goes just upgrade.
I have the 1x carbon xo cranks and like them.
£260 so didn't think they were bad
