Tripster ATR finall...
Tripster ATR finally built up - lush!
260 Users
24 Reactions
30.5 K Views
Apologies for not reading the entire thread but whats the sizing like on these?
I would normally take a 54 id have said im 175cm tall but im thinking looking at the charts id be a 55.5
Ive just confirmed with kinesis the reach on the geometry charts is correct so the reach on a 55.5 is shorter than on the 54. With the change in seat angle the 55.5 is still slightly longer ett but has a higher front
Confused as looking at the size guide id fit 3 or 4 of the sizes
Posted : 12/03/2015 9:21 am
Bump...
Ive read lots and it seems people were stuck size wise between 54 and 57 but they now make a 55.5
I have a pro6 at the min with cbb to saddle top at 740mm and 40mm of spacers under my 100mm 8deg rise stem its a 54cm model but im unsure of tripster sizing
As kinesis confirmed today that the reach on the 55.5 is shorter than the 54 due to seat tube angle and headtube length but the ett still seems longer on the larger. My current reach granted with a long fizik arione is saddle nose tip to touching the bar of 504mm
Bugger lol if it were 54 or 57 id know for sure but 55.5 throws a spanner in the works.
Anyone have a 54 or a 55.5 and a tape measure 😉
Posted : 12/03/2015 6:20 pm
I'm 174cm and have a 54cm .. about 80mm stem I think, Salsa Cowbell 3's
It was 54 or 57 when I bought, and I didn't think too long after reading this thread about going 54.
I'm short of leg and long of torso (and fat of belly but thats not relevant) and the 54 feels right to me - more on the relaxed side than the stretched side, but a 120mm stem would probably swing it the other way. Glad I went 54 over 57 but that is a personal choice, someone more road biased migh have preferred the other. Not much seat post out on the 54 either - would prefer a bit more and a shimmed 27.2 for comfort, but I'm seeing how it goes for now.
Can measure some bits if you draw me a picture 🙂
Posted : 12/03/2015 6:48 pm
The 55.5 has a virtual top tube of 560 which is the same as my roadbike. I'll know this time tomorrow whether it was the right call but i'm fairly confident that it is. I'm 5'10 btw.
Posted : 12/03/2015 7:44 pm
Whats confusing me is 55.5 has a ett 9mm longer than the 54 but the reach on the 55.5 is 5mm shorter than the 54. Its madness lol
Posted : 12/03/2015 8:14 pm
5,11 and on a 54, glad i didnt go for a 57 as the headtube would sit me up to much. I bought mine when the 55.5 wasnt produced, looking at the geo im still glad i have the 54.
Posted : 12/03/2015 8:28 pm
Buzz ive just scrolled thru and found your pic with small spacer up front and neg stem. Would you do me a favour and measure center bb to top of seat and height to top of bars and saddle tip to bar please. How long is the stem btw. Comparing my pro6 set up im thinking a 54 would look similar dimensions to yours when set up . Thanks
Edit.. whats the standover on the 54 as i cant find any figures
Ta
Posted : 12/03/2015 9:02 pm
centre bb to top of saddle = 74cm
centre bb to top of bars = 80cm
centre of bars to saddle tip = 54cm
ground to top of bars = 91cm
Stem is 100mm -10 and as you have noticed i have a 7mm spacer
I do run my saddle slightly lower than most as ive got a dodgy left knee.
Posted : 12/03/2015 9:34 pm
Hmmm, that is a bit weird now you mention it Firestarter
Posted : 12/03/2015 10:10 pm
Thanks buzz one more please what's the floor to top of saddle please im interested in saddle to bar drop. I have my saddle at 740mm too so its looking like a 54 is ideal
Thanks again
Posted : 12/03/2015 10:38 pm
I also have a saddle height of 740mm as measured from centre of bb along seat tube angle, it is 960mm measured to the floor from the rear of the saddle where my sit-bones make contact.
I have a 100mm x 10° thomson X4 stem/20mm of spacers and a Jones Loop bar so i guess that makes my cockpit set up irrelevant as you are going to run drops
Standover with Vittoria Voyager 35c tyres is 805mm measured to middle cable clip on top tube.
Posted : 12/03/2015 11:10 pm
Thanks all it looks like a 54 with small spacer and neg rise stem and seat at 740mm reach is same poss a touch shorter than my current road bike but with a 50mm saddle to bar drop rather than my current 90mm drop. I think the 55.5 would fit but it would need shorter stem and headtube may be a bit too tall tbh.
Best i get creeping round the mrs some more 😉
Posted : 12/03/2015 11:17 pm
Bluesmartie
I run Avid BB7s on a Fargo with Centrelock rotors and have to file the end tab off of one of the disc pads. I suspect that you should be ok on the Tripster with the Spyre and Centrelock set up.
Posted : 13/03/2015 10:15 am
Re sizing. I find the guidelines on the Kinesis website pretty spot on. I ride a 57cm with a 100 mm stem and Salsa Woodchipper bars. I wouldn't get too hung up on agonising over the size too much as you can compensate for things by adjusting the saddle position and stem length and rise. If you want to set it up like a road bike you may already have, that's fine but for me, the beauty of the bike is that it isn't a road bike, doesn't have road geometry and does ride differently. Off road, the longer head tube and low bottom bracket are a boon from my perspective. The more upright front end feels great and makes me wonder why I ever thought arse up, head down was the way to go on my old road bike. Comfort equals speed in my book. 😀
Posted : 13/03/2015 10:21 am
I am in Surrey with a 54, inline post, and 110mm neg rise stem if you are near to try it for size.
Posted : 13/03/2015 11:24 am
Anyone around the NE of Scotland got one my Mrs can try for size? Probably looking at a 52-54.
Not super-urgent, but she's keen to get one in the next few months, and is very nervous of buying any bike without at least sitting on a similar one.
Posted : 13/03/2015 11:29 am
Thats no good without your height sanny lol
I get what your saying but if i can make it fit similar to my road bike but with less of a saddle to bar drop with just using tiny spacer and neg stem it gives me loads of option for raising bar shortening reach with stems and spacers later. I dont want to end up with a 70mm stem and loads of spacers or 120mm stem and none. Shame ive no dealers with stock anywhere near
Thanks turnerguy but im miles away 😉
Posted : 13/03/2015 12:35 pm
What bb are you guys all using?
I must have taken the first 105 bb off and re greased 5 times due to creaking...
Bought a new one but that creaks a bit too. Everything clean and greased before fitting, definitely not over tightened..
Posted : 13/03/2015 1:09 pm
I get what your saying to sanny which is why ive not cut down my steerer right to the stem, if i want to i can flip the stem over and move it up the spacers, thats the beauty of the Tripster.
Posted : 13/03/2015 1:14 pm
Using a 105 bb, covered about 3k so far and no creaking, did have creaking from rear skewer which i initially thought was bb.
Posted : 13/03/2015 1:15 pm
Hi all,
I've been following this thread with interest for a few months now, while trying to find another bike frame that ticks all the boxes the tripster atr seems to have covered, but at a better price.
I've been tempted by the pickenflick, and would probably get one if it wasn't for the lack of mudguard mounts. I've looked at aluminium frames, but I've never had one I liked; carbon isn't my thing, so back to Ti where things are a bit too racy or super expensive, and nothing else seems to come close to the amazing tripster for versatility.
There are some great bikes on this thread, and I would probably buy a frame and build it up with bits I have.
Am I right in thinking that the price for the frame has gone up steadily over the last year? It still seems a lot to me, but I could probably sell three bikes, whose duties the tripster will hopefully fulfil, that should cover costs. The thing is, I'm bad at getting rid of things so it's tough! Waiting for a special offer, but prices seem to be the same wherever I look.
An old and dull question, but has anyone weighed a large frame, fork and headset as it comes when new? Interested if claimed weights are accurate.
I'd go for a large, as at 6'1" I like a 57 top tube.
Cheers.
Posted : 14/03/2015 11:15 am
Can someone please explain how to post photos on here?
Posted : 16/03/2015 8:15 pm
http://singletrackmag.com/forum-help/
Posted : 16/03/2015 8:16 pm
Great thankyou
Posted : 16/03/2015 8:19 pm
I think I paid 1350 for my frame from fatbirds.
However it does seem like it is a keeper bike, which makes the cost/vfm proposition different.
Posted : 16/03/2015 9:14 pm
That price seems to be the best at the moment and I guess it will only go up! It's just that it is twice as much as I paid for my last titanium frame, an enigma, but that was about 7 years ago. I guess I need to re-assess things, but will it be £1200 better than my second hand surly cross check? That's one of things you can't really answer I guess.
Posted : 17/03/2015 10:12 am
 imn
@Cloudnine - have you faced the BB shell?
Posted : 17/03/2015 12:45 pm
No didn't face it. I'm not actually convinced it's the bb now.. Maybe it's the wheel.
Only does it under load and stops in the rain.
Have been looking at Ti seat posts.. But don't have a huge amount of post showing.
How much difference will Ti make? Are those J&L ones ok?
Posted : 17/03/2015 1:41 pm
 ff29
Hello Everyone. I have been drooling over this thread for weeks. I saw the tripster at the 2014 London Bike show. Since then have not been able to get it out of my mind. I ride MTB and road but have become increasingly frustrated about not being able to take carbon road bike off onto the bridleways and do some touring. Same bridleways on MTB are just to slow and tedious so ATR seems perfect to cover long distance in good time and do some bike packing.
Go easy on me but here comes the what size frame question!
I am 5 feet 69?64 inches (168cm) Inside leg of 30.7 inches, My road bike is 56cm Boardmans Team Ltd edition. Running a 100mm stem with 3T ErgoNova(42cm). Reach on the drops feels fine.
Personally it feels just bit to high for me on standover. There is space but not much. 51cm ATR seems to be just on the smaller edge for me and 54 seems the logical choice, but is it? Want to run a slightly smaller stem, 90mm with Jones Loop Bar after some of the comments about slowish steering. Somafunk your bike is a work of art! Love what you have done with the dynamo hub and steering bung. Where did you get your ESI grips from? They look like the long ones? I could only find them on the Jones website. 🙂
Posted : 21/03/2015 6:21 am
cloudnine
I know where you are coming from, had the same on my Rose, took everything apart, re-greased, had a new BB fitted, eventually I tracked it down to my rear quick release.
I've got a set of Mavic's on mine, changed the QR, things are much better, but not perfect.
Posted : 21/03/2015 5:43 pm
ff29 : Cheers for the comments regarding my tripster, Work of art?….. I can only claim to stealing others ideas from around the net - it's really just a [i]mongrel[/i] bike as i've only chosen components that i wanted for it and attached them to the frame.
I bought the long ESI grips from charlie the bike monger, designed especially for the Jones bars.
You're pretty much the same height/leg length as me and i guess it depends on whether or not you want a higher front end (54cm) or you are happy with a lower front end (51cm), i made my choice for the 54cm with a higher front end as i didn't want a stack of headset spacers which is what would have happened if i went for the smaller size - where are you in the country? - there's quite a few tripster riders up n' down the country and I'm sure someone will let you swing a leg over to check for sizing.
Personally i'd go for the 54cm.
Posted : 21/03/2015 6:51 pm
 ff29
Ta Somafunk. That rings true with me. 54 it is. Not a big fan of headset spacers and tend to keep them to the minimum. Based in London.
Work of art. Yes for sure in a bikey anorak way! If you say it is a mongrel it is a very classy one. Never in a 1000 years would I have dreamed of drilling a carbon fork and dremelling the headset like that. Your bike is so sorted for climbing on and doing epic adventure touring.
Thanks for the tip on the grips. I was googling and could only find mention on the Jones website in the US. Daft considering, I got my Jones Bar from Charlie! Have ordered some grips. Intend to run the Jones bar on my 29er until I get my ATR frameset and build that up.
Posted : 21/03/2015 8:52 pm
I have a dilemma. Last day of the on-one 15 percent off today making the Pickenflick a bargain. I know the tripster is what I really want, but is it worth £440 quid more for mudguard eyes, a higher front end and a more relaxed ride? Not having ridden either I have no idea. Decisions, decisions...
Posted : 22/03/2015 12:13 pm
So I've been lurking here for a while, prompted by a desire for a Tripster ATR.
In January some scumbags stole my wifes and mine 5 bikes from our garage. Thankfully we were insured. So began the great bike hunt.
Beyond my mtb I had a cross bike and road bike to source. That was until I started looking at adventure/gravel bikes wandering whether combining the budgets would yield a decent all-rounder.
The GT Grade and Jamis Renegade were the front runners until I came across the Tripster ATR. I'd never ridden a Ti bike before and was visually smitten. I rarely buy anything without tons of review trawling and have gotten adept at sorting out genuine negative comments from disgruntled individuals. Not that there was any need for that however, as I have yet to find anything even remotely negative written about the Tripster ATR, be that professional or user reviews. There can't be many things that attain such acclaim!
Anyhoo, after viewing all of the great pics on this forum I bit the bullet, ordered a frameset and enough components to prompt the bank's fraud team into blocking my debit card! A week later its finished, and as this thread sealed the purchase I thought I would upload the results. Thanks for all the indirect inspiration 🙂 Now for the first proper ride!!
https://drive.google.com/file/d/0B8d-282Zh9DkTDN5LXRNbjZkOEE/view?usp=sharing
https://drive.google.com/file/d/0B8d-282Zh9DkR0VsN2RBOU9BOFU/view?usp=sharing
https://drive.google.com/file/d/0B8d-282Zh9DkMk90MjhQb0gwemc/view?usp=sharing
https://drive.google.com/file/d/0B8d-282Zh9DkbzJkaXAxVjhaalk/view?usp=sharing
Posted : 22/03/2015 12:46 pm
Images for post above:
Posted : 22/03/2015 1:16 pm
Cornishboy01:
Does it ride as good as it looks? What size is that and do you find the head tube too long?
Pickenflick or atr? Bargain vs beauty...
Posted : 22/03/2015 1:30 pm
root-n-5th
Yes it does ride as good as it looks. It covers ground quick enough both on road and off. Slightly more forgiving geometry than the cross bike it has replaced, which made me fear it may not climb so well but I live on the rather hilly North York Moors and it does pretty well in my book.
I'm 5'8" with a 30" leg. I went for the 51cm frame even though the size guides indicated a 54cm. So glad that I did too as the 54cm would have been way too long in the top tube for me - even with the 70mm stem I am running. The head tube seems fine to me but I did leave the steerer a little longer than normal with a spacer above the stem as I want to be able to ride this bike long after I am no longer supple enough to lean over low.
Posted : 23/03/2015 9:56 am
So, I got hold of a Tipster last August, rode it for a few months, loved it. Then after a cold & wet January ride I managed to drop it of the roof of my car. Wind resistance yanked the bike out from the clamp round the down tube, pinching it both sides. [img]<img src="https://farm9.staticflickr.com/8646/16183784721_a6a6384c1b_m.jpg" width="240" height="135" alt="beyond economic repair">[/img]
I made an insurance claim and now have a new frame. I loved the tipster but wanted a slightly different fit not offered by any of the stock Tripster sizes, so ordered a semi-custom Stoater. So here is the deal, I've a damaged 54cm Tripster frame and fork going spare. [img] https://flic.kr/p/r4KxmT [/img]
Should I try and sell it? Would anyone buy it? Is it wroth getting repaired? What to do with it
Posted : 24/03/2015 10:19 am
let's try posting images again.
[url=[url= https://farm9.staticflickr.com/8646/16183784721_a6a6384c1b_m.jp g" target="_blank">https://farm9.staticflickr.com/8646/16183784721_a6a6384c1b_m.jp g"/> [/img][/url][url= https://flic.kr/p/qE78n4 ]beyond economic repair[/url] by [url= https://www.flickr.com/people/124469934@N06/ ]j_c_gillies[/url], on Flickr]Dented downtube[/url]
[img][url= https://farm8.staticflickr.com/7570/15999877287_ef47c9df0b_m.jp g" target="_blank">https://farm8.staticflickr.com/7570/15999877287_ef47c9df0b_m.jp g"/> [/img][/url][url= https://flic.kr/p/qnRy6e ]DSC_000001[/url] by [url= https://www.flickr.com/people/124469934@N06/ ]j_c_gillies[/url], on Flickr[/img]
[img][url= https://farm9.staticflickr.com/8673/16451363999_35ca375460_m.jp g" target="_blank">https://farm9.staticflickr.com/8673/16451363999_35ca375460_m.jp g"/> [/img][/url][url= https://flic.kr/p/r4KxmT ]DSC_0431[/url] by [url= https://www.flickr.com/people/124469934@N06/ ]j_c_gillies[/url], on Flickr[/img]
Posted : 24/03/2015 10:39 am
I can't overstate how important on a bike like this (for me) it is to have mudguard fittings and clearance. Your intended use is no doubt different. But many cyclists buy a new bike for best use and eventually move it to poor weather duties. For me (not you, not everyone) the massive clearance and mudguard capability is what makes the Tripster such a fantastic bike. I love it.
I think it's worth the extra over the Pick N Flick.
Posted : 24/03/2015 10:54 am
Sneaky peak of my build, just waiting for my Mason X Hunt wheels to arrive before completing it....
Posted : 26/03/2015 1:55 pm
Your workshop is a bit cleaner than my garage 🙂
I just sort of threw bits at the frame till they stuck in vaguely the right places.
I've no idea, but if you're 100% honest in selling, the buyer views and accepts the risk, I don't see why you shouldn't sell it and move on. I wouldn't expect a fortune for it, but the fork alone is probably worth £100??
Posted : 26/03/2015 5:00 pm
I might be interested in the forks if you are selling them
Posted : 26/03/2015 8:07 pm
 dmc
Id be interested in the frameset what you looking for it ? pm please
cheers
dc
Posted : 26/03/2015 10:30 pm
@cloudnine … yep the forks are for sale. just email me.
@dmc … just email me to
Posted : 30/03/2015 3:12 pm
Hi James, what's your email? It's not in your profile.
Posted : 30/03/2015 5:31 pm
 dmc
Hi James cant find an email mines in my profile
cheers
Dc
Posted : 30/03/2015 8:51 pm
 Rik
How are you all finding the 'feel' of the bike and the steering?
Looking at the geometry figures of the Tripster atr:
The 70.5 head angle, and a 45mm rake fork produces a bike with a high trail figure. This should mean that it should be stable at speed but slow steering maybe with a bit of wheel flop???
Couple that with an ultra low bb drop will mean you have a very planted bike. Great off road but what about on road?
What's it like compared to a full road bike (if you have both)??
Posted : 02/04/2015 2:20 pm
Rik, hard to do a direct comparison as I sold my Giant OCR to part fund the Tripster - it's taking 2 bikes roles in 1 for me.
I'm also riding with 32mm cross tyres rather than road rubber at the moment.
Biggest difference in feel is the CowBells - drops feel a lot more usable with them on than normal road drops. You may not agree.
It's my utility bike so is often accompanying a single speeding / scootering 4 year old.. don't have any issues with the steering at his pace or trying to catch his older brothers.
Interested in seeing how it performs in 'roadie' guise (25mm tyres, lighter road pedals) but having a bit too much fun on the CX setup at the moment 🙂
Posted : 02/04/2015 3:35 pm
 Rik
I've got 4Season 28c on my road bike and 35c Marathon Supremes on my touring bike - the difference between the two are not that much for everyday use. The supremes are so much faster than a normal marathon.
Cowbells on the touring bike and 3T bars on the road bike. Both are comfy, but i don't ride on the drops ever, 99% on the hoods.
Just wondering if it feels slow and sluggish in comparison to a road bike or even cross bike which will have steeper geometry. Or if it doesn't feel slow and sluggish but planted and stable in a good way???
Posted : 02/04/2015 4:13 pm
The latter. It is a great bike to ride.
Posted : 02/04/2015 4:15 pm
Finally got round to taking pics. Just uploading them to photobucket
Posted : 06/04/2015 12:50 pm
Posted : 06/04/2015 1:18 pm
My initial thought when I got on it for the first shakedown was 'Holy crap. Have I done the right thing?'. I had been riding an old Time race frame as a commuter after my Kaffenback snapped, and that had a 73.5° HTA. In comparison, the Tripster felt very odd to start with. After 2 months, I don't even notice any more. Even swapping back and forth onto my current race bike (73° HTA) I don't notice as much.
Posted : 07/04/2015 9:43 am
 Rik
Thanks Matts that's good to know the 70.5degree head angle does seem slack
Posted : 07/04/2015 10:33 am
Yeah. I was really questioning whether I had bought the right frame for a couple of days. I wanted something that would handle OK for some off road bikepacking and playing about in the woods, but in reality, 95% of the miles I do on it are commuting and training. Happily, now I'm adjusted to it, I like how it handles.
Posted : 07/04/2015 11:05 am
I thought that at first coming from a 2012 Croix de fer, then I got used to the stable steering versus the quick steering of the CDF, so instead of darting around I now 'power-out' of turns, working against the stability of the steering.
And for longer rides the stability is good as you aren't concentrating on keep the steering straight, and can just concentrate on slogging on.
But the bike felt a lot less sluggish with 40c tyres on and feels 'right' now. And the WTB Nanos are pretty fast on the tarmac as well.
Posted : 07/04/2015 11:22 am
It seems like the rear brake caliper faces on my frame are too rounded - I can't align the TRP Hy/Rd properly against the disc. As soon as I tighten the bolts it angles inward slightly and goes out of alignment, resulting in fairly bad pad/disc rub.
Has anyone else had this, and if so did you use shims, or get the frame-caliper mount area faced? I'm also considering getting the Avid bolt kit which has the angled washers, but I'm not sure whether that will raise the height of the caliper too much, or if that must might not be the best option 🙁
... or I just might be doing something wrong, but I've spent several days checking things and the disc itself appears to be spinning perfectly true. I've also checked a new spare disc, just in case I was missing anything. The wheel itself was built by a reputable local builder and also looks perfectly true.
I've also checked for debris anywhere on the caliper and frame - everything I've looked at has been perfectly clean. The Hy/Rd mounting surface is flat, but the frame mounting area isn't.
The front caliper is perfect. I've also swaped the front & back, with the same result - front is still perfect, rear still has this problem.
Posted : 14/04/2015 9:51 pm
Very excited to receive my Mason X Hunt 4seasons wheelset today, rotors and cassette fitted at lunch, tubes and tyres now fitted. Won't be long before I'm on the road now!
Posted : 16/04/2015 7:50 pm
Re-shod with some 41mm Surly Knards on Saturday and went for a blast round Epping Forest on Sunday. Damn, this bike is fantastic!
Posted : 20/04/2015 10:37 am
Hi,
Just wondering if anyone has any trouble with pedal strike on roots and rocks, etc, when riding off road, due to the large bottom bracket drop?
Cheers.
Posted : 22/04/2015 8:44 am
Have been riding mine off road for the last couple of weeks. Haven't clipped a pedal yet. Not done any really uneven rocky stuff though.
Posted : 27/04/2015 9:31 pm
Has anyone ran one of these with a flat bar set up?
I am edging towards one but something is calling me towards a flat bar with bar end type set up.
I never ride on the drops, the vast majority of my time on the roadie is spent on the hoods.
Most of the time I would be running 28mm GPs for road riding but fancy hitting up field edges etc on occasion.
Thoughts please... not sure how i'd go about sizing either??
Feel free to explain what a stupid idea it is!
Thanks
Posted : 02/05/2015 10:18 am
Thanks for info on bottom bracket drop off road. I think it will be ok.
Mbnut: I haven't tried a flat bar on this frame but the usual problem is the top tube is too short as it is designed for drops - It might be a bit upright and squashed, or you can run a very long stem, but then the steering will be ponderous with the 70.5 degree head angle.
I have a sizing question for anybody out there. Sorry.
I'm 6'1". Folk law would say a 57, but I will be riding off road a lot and really want a 56cm top tube. Anybody of my height out there riding a 55.5cm tripster? I have found one in that size at a good price. I often find bikes that are meant to fit me a little long.
Cheers.
Posted : 02/05/2015 11:01 am
http://www.profile-design.com/product/base-bars/t2-wing/
This sort of thing is what I am thinking.
Then I could run the standard brake/shifter set up I think and it would deal with the sizing to some degree.
I am scrolling through but if anyone has pictures of this kind of set up that would help.
Thanks
Posted : 02/05/2015 11:38 am
I have a Jones bar set up on mine, from page 42 onwards.
Posted : 02/05/2015 2:03 pm
Root, instinct is that a 55.5 might be too small. That size fits me perfectly for off-road riding and I'm 5'10. I ride a 56 top tube road bike. Maybe you'd be ok but you'll be right on the limit I reckon.
Posted : 03/05/2015 9:19 pm
Curto80: Thanks for the input. Do you ride with a long or short stem? I suspect the 57 would be better if I'm honest. Pity it's not in stock at the price I've seen.
Posted : 04/05/2015 11:30 am
The bike could handle the endless dried-out hoof terrain around Lewes but I couldn't. Totally shagged.
Posted : 04/05/2015 2:41 pm
Bridle ways can be the worst trails to ride on in many conditions. Bit smelly too.
Just thinking about sizing and the reach measurement on the 55.5 and 57 is almost identical. The only difference seems to be the stack height - obviously higher on the 57. So maybe the 55.5 would fit...
Posted : 04/05/2015 4:43 pm
Not sure where you're based but if you happen to be passing Winchester you're welcome to come and take mine for a spin.
Posted : 05/05/2015 6:45 pm
FYI there is a fully built up Tripster for sale (new) in Prologue in Harrogate.
Posted : 05/05/2015 9:00 pm
OK. Loving my Tripster on the few occassions i get out to ride at present. It's got me thinking as I'm never using the drops and never in the big ring so...............
Flat bar conversion with Titec J Bars (i love them)
1x11 XT groupo with discs. (when released and saved up for)
36t up front on a narrow wide doofy thing
11x40 at the back.
Am I missing anything other than making the bike more about me and my riding than about general aesthetics?
Flame, suggest, recommend, etc :O)
Tim
Posted : 06/05/2015 7:20 am
Hi all
Sad times for me I'm afraid... But might be good for someone waiting for a Tripster?!
I know this is the Tripster ATR tribute/tech/support/admiration/enthusiast (of which I'm one!) thread (which I've followed for ages in considering/waiting for my bike) and not a For Sale thread as such, but I've only just decided tonight that due to a 'financial shortfall' I'm going to have to put her up for sale and figured she should go on here first before I even think about posting/selling elsewhere. I've got a house that needs serious work doing to it and my Tripster is unfortunately my best (and most prized!) asset and something I simply can't afford to keep in my current situation.
The bike is as new and can't even be classed as being used - she has only been ridden ten minutes to work twice on the road - and there is absolutely no wear, tear or marks whatsoever (I would upload pictures but on my tablet it either asks for a url or crashes!). She is essentially a brand new, very high spec, unique, custom bike with an outstanding high quality parts list, as you can see below:
Kinesis Tripster ATR Titanium Frameset - Size 54
Kinesis Crosslight CX Wheelset (Campagnolo Freehub)
Continental Grand Prix 4 Season 28mm Tyres
New for 2015 Campagnolo Chorus Groupset:
Campagnolo Chorus Carbon Chainset (a real work of art!)
Campagnolo Chorus Carbon Rear Dérailleur (another work of art!)
Campagnolo Chorus Front Dérailleur
Campagnolo Chorus Carbon Ergopower Levers
Campagnolo Chorus Cassette
Campagnolo Chorus Chain
Campagnolo Super Record Bottom Bracket
TRP Carbon Crosstop Secondary Brake Levers
TRP Carbon SLC Front and Rear Disc Brakes and Rotors
Thomson Elite X4 110mm zero rise Stem
Ritchey WCS Carbon LogicCurve Compact Handlebars
Ritchey Bartape
Ritchey SuperLogic Carbon One-Bolt Seatpost
Ritchey Carbon Bottlecage
Brooks Cambium C15 Limited Edition Slate Grey Saddle (no. 205)
XTR SPD Pedals
SKS Chromoplastics Mudguards (with custom bolts for better more uniform fit)
As you can see from the spec, there's no way I would have built the bike up, waiting over months and months for the frame to arrive and to subsequently (lovingly?!) select and purchase all the parts (finally getting her assembled at my brilliant LBS who also provided the frame and most parts and are an official Kinesis dealer) with any intention of selling, and I'm gutted to be typing this out. I've spent an absolute fortune on this bike (around 4k all in) and know I won't get that back but will consider any offers of 3k+ for the complete bike, which I think is very reasonable indeed for what is essentially a very high spec, high grade materials, as new, warranted, 'boutique', iconic bike. If need be, I'm prepared to keep the saddle and pedals if you already have your own in mind.
It will also mean that you can grab a new ATR that's ready to ride rather than waiting for one (I understand the current backorder time is still 4 weeks plus), and as I'm sure you can see the spec is outstanding (and rare too with 2015 Campy Chorus which, like all parts on this bike is a joy to behold!). I stand by this bike, it's a genuine, reluctant sale and believe me, if I could afford to keep her I would, but needs must 🙁
The bike is available for collection from the West Midlands, and I hope you can appreciate why I have posted initially on this thread.
Emails, photographs, a cup of tea and biscuits etc aren't a problem, and it's important that the new owner is happy, which I know you will be once you see her. My loss is someone's gain so to speak 🙂 I'll miss her.
Posted : 06/05/2015 11:38 pm
Shit! 😥 , sorry to hear that grizzly, A very individual and tripsterish build you've done with the campagnolo - they may be a [i]mass[/i] produced (in the best sense) frame set but it has the the ability to accommodate individual build quirks (see my build on page 42 for example) ..........just keep the thought in mind that once your over this financial crisis and back in the black you'll come back to this thread with a new build.
Posted : 06/05/2015 11:50 pm
Cheers Soma, much appreciated, I absolutely love the build (and your several incarnations along the way too!) and the way that the bike has worked out (wish I could post some pictures up but it seems impossible unless I can mail them someone first or something?!) and its crushing to have had to have clicked "Send Post", but sometimes reality bites doesn't it 🙁
Still, if it goes some way to resolving things, there'll be another happy Tripster owner somewhere, and I know she'll get looked after having gained a cult following: like me, initially inspired by - and best recorded on - this thread 🙂
Thanks buddy
Posted : 07/05/2015 12:01 am
Mail them to me (email in profile) and I'll post them, be a pleasure to show it off
Posted : 07/05/2015 12:03 am
Smarr :
Has anyone else had this, or get the frame-caliper mount area faced?
I faced head tube, bb, brake mount before I built my frame up. Seat tube was slightly oversized but my Lynskey ti seat post with carbon paste hasn't slipped. After the debacle with my cove hummer (sans facing) a few years ago I treat every build from a [i]grounds up[/i] first perspective.
Posted : 07/05/2015 12:18 am
Curto80: Thanks for the offer of the ride. I'm in South London so a bit of a journey, but it's not beyond the realms of possibility.
Posted : 07/05/2015 10:41 am
Curto80: I've just had a thought about measurements. Could I ask how high you have your saddle? I run mine at 75cm, which I think is quite low for someone of my height. Be interesting to compare.
Cheers,
Sam
Posted : 07/05/2015 11:33 am
Page 21 / 35
