Triple or double ch...
[Closed] Triple or double chainset best if converting to 1x?
7 Users
Hi folks
So which should I get if I want to be able to turn it in to a 1x set up.
Is a triple better (thinking I'd put the single ring in the middle for the best chainline position) or is it better to use a double, and the single ring goes on the outer position?
Not sure if the outer on a double is the same position as the middle on a single? Which option would give the best chainline?
Spec for my bike says it needs 50mm chainline if that makes a difference.
Posted : 16/03/2013 8:56 am
I use an XTR double, because that's what the bike had, and it's been fine, getting a chainring was a problem because its an 88mm BCD, but if you get the trail double, or any other groupset that's not an issue.
Starting from scratch I'd probably get the triple to convert.
Posted : 16/03/2013 8:59 am
Maybe I'm missing the point, but you could just but a 1x10 chainset?
Posted : 16/03/2013 2:51 pm
I asked [url= http://singletrackmag.com/forum/topic/double-or-triple-chainset-to-run-single-ring ]here[/url] last week and was advised on a triple, which I now have sat in the bottom of my wardrobe waiting for me to decide on a frame.
Posted : 16/03/2013 3:53 pm
Thanks fathomer, hadn't seen your post, must search first next time! Based on that and njee's experience triple seems the best option.
endurancenut - sorry, I should have mentioned I want to have the option of running full range of gears and front mech too in case I don't get on with 1x or going places with more hills.
Posted : 16/03/2013 4:02 pm
You might want to consider a crank that has a detachable spider. You can then replace the spider with a chainring. I did this with a Truvativ X9 crank and MRP Bling Ring - just like this -
Posted : 17/03/2013 9:11 am
An SLX double is definitely different from a 'standard' triple. The only reason I know this is that a Stinger fits my SLX with no faffing but trying to get it to work with a RF triple I had no joy no matter what spacer arrangement I employed. Single ring looks like a better option though...
Posted : 17/03/2013 9:54 am
SRAM crank an bling ring for me works very well
Single speed uses a middle burn rs8 and UNO ring
And also works perfect
Posted : 17/03/2013 10:53 am
It also depends on what/whether you run a chainguard.
The bolt-less setups like the UNO and the X9 pictured above obviously won't allow you to run a bashring, without a spider change.
FWIW, on both my bikes, I run a single 32t ring on a SLX double c/set with the ring on the inner position, and a bash on the outer, and a Straitline SilentGuide. Works a treat.
Posted : 17/03/2013 12:39 pm
