Trek Stache strangl...
[Closed] Trek Stache stranglehold drop out replacement
2 Users
Bust my Stache’s mech hanger this morning; anyone know where I can find pdf/video showing how to replace please.
Posted : 26/11/2019 3:56 pm
Done mine on my stache. It's really easy.... Undo the tension nuts (the small ones poking out the rear of the dropouts). Use a spanner to remove the dropout nuts.... Don't forget the bolt on brake mount as that slides out with the dropout.
Stanglehold is used on a range of bikes not just the stache... This may help (link at bottom)
You can't really go wrong to be honest! Just nip up the axle with the wheel in to ensure the dropouts are parallel before tightening everything up. I run my stache with the axle in the middle of the slot but stock on 29plus wheels it should be furthest to rear (max wheelbase). Its a great system, tried single speed with it but need the gears!
Posted : 26/11/2019 7:34 pm
