Trek Remedy 7 and B...
[Closed] Trek Remedy 7 and Blackspire stinger
1 Users
Fitted my black spire stinger to the ISCG mounts (no washers) on my (2010) frame and then re-fixed my crank arms and annoyingly the bolts on the crank that hold the sprockets on hit the bolts that fix the stinger to the ISCG points (the protrude very slightly from the stinger) when you spin the crank, its very close and they only just hit but cant screw them in any more.
Would it be stupid to add an extra 2.5mm spacer to the drive side of my bottom bracket even tho its set up right? (checked the shimano docs)
Anyone else had this problem?
Posted : 25/04/2012 9:44 pm
