Any help appreciated!
I have shortened my dual air 2012/13 RCT3 29er revelation by adding spacers currently running at 120mm.
My question is - can I add more spacers to shorten it further without impairing performance?
Not sure I want to - but would like to know if I can.
Regards
Can't help you there but I have the same forks, these ones [url= http://www.chainreactioncycles.com/rockshox-revelation-rct3-29-dual-air-1-5-taper-2012/rp-prod94599 ]2012 RCT3 29[/url]
I presume this is the guide, says 2011 but think they are the same air wise [url= http://cdn.sram.com/cdn/farfuture/1j0C-YHPEPcN934SsecrStnZtxou5eq_mQmlZAJSDKc/mtime:1372788169/sites/default/files/techdocs/2011-revelation-technical-manual.pdf ]2011 Service guide[/url]
Where exactly did you put the spacers? The guide says between the base plate and the negative piston but makes no mention of the negative piston top out bumper, the aluminuim support washer or the wavey washer (page 13 in that guide)
I'm guessing the spacers go between the negative piston and the negative piston top out bumper.......or...the other side ie between the wavy washer and the base plate?
Any help would be great thanks
