Travel adjust Manit...
[Closed] Travel adjust Manitou Marvel Pro 29er 100mm (2016)?
3 Users
Looking at buying a used pair currently set at 100mm. I fancy playing at 120mm but option to go back to 100mm if i want to. Found some posts suggesting these can be 80-100-120 but wanted to check with the mighty STW-hivemind.
Any info?
Thanks
Chris
Posted : 06/04/2017 7:45 am
 poah
They did used to have a spacer not sure if the new ones do. Check the manual.
Posted : 06/04/2017 7:51 am
Ignore me, didn't win the forks!
Posted : 06/04/2017 10:06 am
my towers needed spacers to reduce travel- you remove them to increase it
I ended up with a load of spacers so if anyone needs some let me know
Posted : 06/04/2017 1:43 pm
