Transition Patrol 2...
[Closed] Transition Patrol 2017 - real world reviews?
21 Users
Seen the NX base model for a good price. Yari etc. All looks good, basic kit and a very tidy looking frame with a proper B.B.!
What are transition like for reliability, pivot bearing life etc?
Anyone got one, is it as good as ‘they’ say?
Posted : 21/11/2017 9:04 pm
I've got a 2017 Scout and love it.nive only has it a few months so can't comment on bearing life etc.
It's a bit heavy for a bike with that much travel but it's a hoot to ride. I imagine that the Patrol will be the same, just bigger.
Posted : 22/11/2017 10:24 am
 poah
I would make sure the bearings are packed with grease and don't expect them to last long.
Bike needs to be ridden hard to get the most out of it. The deluxe is better than the monarch. chainstays can problematic for cracks.
Posted : 22/11/2017 10:36 am
Recently changed the bearings on my 2016 after well over 18 months of hard use including Antur Stiniog, Lakes, Ard rock etc.
Love mine - cant see me changing it any time soon
Posted : 22/11/2017 3:01 pm
 wl
Mate's Transition always had a loose back end - too many pivots. Rode well enough tho. Might not be so much of an issue on newer bikes.
Posted : 22/11/2017 3:04 pm
I've got 2017 patrol and it's been rock solid since day one, all the bearings are still going strong and I'm pretty unsympathetic in my riding and have been known to jet wash the thing every now and again 🙂
Great fun to ride as well.
Posted : 22/11/2017 3:10 pm
too many pivots
Same as any 4 bar/Horst link/VPP bike
Low quality bearings used or an issue with the way they're mounted? Nothing unusual about the design looking at pics
Posted : 22/11/2017 3:17 pm
Are they? Not heard that one or seen owt on the likes of MTBR / PB where that sort of stuff normally goes nuts.
I have seen one or two grumbles about bearing quality though. Mine seem ok so far and it’s been bloody wet since I’ve had it.
Posted : 22/11/2017 3:29 pm
I have a smuggler, it's been great, bearings are pretty well protected, nearly 4000 steep wet Scottish km and I've only changed the bearings once, though I never jetwash.
I think there have been a few carbon patrol rear ends going in nz, but that's the polar opposite of the style of riding I do here anyway.
I've got a Scout and love it.
However, the bearings don't seem to last well before they seize. Approaching 4k kilometers in the last 18months and I've just put the fourth set in.
Posted : 22/11/2017 3:38 pm
 poah
It's not that they are like lappeires but they can go. Read the patrol/scout/ suppressor thread on PB.
Bearings are low quality and generally low on grease.
Posted : 22/11/2017 3:43 pm
I have a 2015 Scout. Best bike I ever owned or rode. If I ever buy a next bike, it will be a Transition.
Posted : 22/11/2017 3:47 pm
too many pivots
Oh dear.
2018 smuggler on order, can't wait
Posted : 22/11/2017 3:49 pm
2016 patrol here. I bloody love it.
When I got it I pulled all the bearing seals and packed them with grease. Most of them were borderline dry. Still on then over a year later, including multiple uplift day's, Ard rock, Cannock, south downs grit etc
I think I should be itching to change it, but I'm not. There's literally no bike out there I want more.
Posted : 22/11/2017 4:00 pm
complete opposite of my experience!
Posted : 22/11/2017 4:42 pm
I've got a 2015 scout and as above I absolutely love it.
I would also agree that the bearings do need some attention and more frequent maintenance (in the peak anyhow).
Even good quality max enduro ones can suffer (especially the lower BB ones)
I changed mine last week and got some good quality marine grease which I've used to repack them
Over thing to note is that there are 4x 3802-2RS which for some reason I can't quite work out cost £20 each.
Patrol or an airdrop edit will almost certainly be my next bike
Posted : 22/11/2017 6:36 pm
 poah
Think you are looking in the wrong places for bearings
Posted : 22/11/2017 7:06 pm
Merlin have some discounted Transitions.
Posted : 22/11/2017 7:58 pm
 rs
I heard some 2016's came with little grease in the bearings, 2017 were better, I had one of the first 2017's and the shop said they checked the bearings and they were fine. Its been fine in the year and a bit i've had it. I found it performed great if I was charging hard, but too firm if cruising a little more, removing tokens softened it up a little, made it more plush and comfortable.
Posted : 22/11/2017 8:13 pm
Thanks for all your comments. Still tempted but I’d like to sit on it but the shop is too far away. Ah well...
Posted : 22/11/2017 8:22 pm
I've really liked mine. it was the 2017 model and I have just put fresh bearings in after 12 months of ownership maybe only 6 months of riding though due to injury. Shameless plug alert Mines for sale (Sentinel on the way)
https://www.pinkbike.com/buysell/2263073/
Its a custom build, not the NX build and you could test ride it in the lakes!
Posted : 22/11/2017 9:49 pm
I have been looking at them. Looks awesome, but thinking that they are too much bike for my needs.. Looks like you need to rag it to get most out of it
Posted : 22/11/2017 9:58 pm
too many pivots
Just enough I think they would say, if you compare it to orange then there are a good few more! However it just means if you crash and break/crack a part of your rear triangle you don't have to replace all of it.
Posted : 22/11/2017 10:41 pm
2015 Patrol here. Also had some issues with the bearings but other than that I really like the bike. It's a big bike but really versatile. Also quite forgiving, doesn't require you to ride aggressively for it to work. Pedals notably better than my previous kona process 153 too. Been itching for a new bike for a while but haven't really found one which would be a notable improvement yet. Just got a coil shock for it, interested to see how that turns out.
Posted : 22/11/2017 10:50 pm
2016 Patrol. Follow the Transition guidance for pivot bolts and they won’t come loose. No issues with bearing wear - I ensured they were all suitable greased and none have been problematic.
Bike rides really well - always enjoy it and it is far more capable than me! As for breakages I weigh 100kg nekkid and significantly more when I am in ridding gear. 6’ drops and lots of rock gardens have not broken anything yet. Fingers crossed!
Posted : 22/11/2017 11:37 pm
Been running a 2017 Patrol Carbon for 10 months/2700km.
Regreased the bearings at 1600km but otherwise been running fine and I have a slight reputation for destroying stuff.
I think the early releases had issues with the cable management on the chain stays but can't say I have heard anything else.
Metric Super Deluxe is good but fitted a Push 116 which is betterer.
Superb bike, only real drawback is its a tadge heavy.
Posted : 23/11/2017 12:07 am
