Transition covert 2...
[Closed] Transition covert 2012 650b conversion
4 Users
 deca
Does anyone know if you can get the rear coversion as have seen pics on internet
Posted : 09/01/2015 9:36 am
Have seen someone post up about it on MTBR (go to the Transition forum) Don't think he changed any drop outs or anything just stuck a 650b wheel in there.
Dunno why you would tho #26iskeepinitreal 🙂
Posted : 09/01/2015 11:52 am
I emailed Transition about this early last year and they seemed to think there would be clearance issues.
Borrow a 275 wheel and let us know.
Only problem is the BB will go up and you won't be able to compensate with offset bushings. Maybe a -1/1.5 headset could help a bit.
Are the Covert 275 dropouts different to the Covert 26 or did they change the whole rear end?
Posted : 09/01/2015 12:54 pm
I've just built up a used Bandit frame and I'm thinking I might do the same if the rear will take a 650b. No rush mind you, but it'd ease any eventual abandonment of 26". I think maybe the Bandit would be ok with having the BB a bit higher.
Posted : 09/01/2015 2:43 pm
