Trailraker 2.1 on F...
[Closed] Trailraker 2.1 on Flows, air leaking through sidewalls.
6 Users
Thought I'd see if my trailraker would work tubeless. It went up straight away so put in a cup of stan's sealant. It kept slowly going down, I put soapy water around the tyre and noticed air was leaking from a few areas around the sidewall. Thought it would eventually seal but it keeps going down. Do I give up or put in more sealant? The rims are ztr flows.
Posted : 20/11/2013 8:10 pm
Tape or Rim Strip?
Posted : 20/11/2013 8:11 pm
More sealant, slosh about and lay it on its side, on a bucket. Slosh the sealant around again and repeat.
Posted : 20/11/2013 8:19 pm
Yellow rim strip. Gonna put more sealant in then. Cheers
Posted : 20/11/2013 8:47 pm
More sealant and then ride it - best way to get the sidewalls properly coated.
Posted : 20/11/2013 8:53 pm
Have you ridden it? Most tyres continue to fizz til they've had a ride IME
Posted : 20/11/2013 9:45 pm
Not ridden it. Seems to be staying up now though. Will be riding a lot at the weekend 😀
Posted : 20/11/2013 10:31 pm
Try lying them on the side allow to fizz/seep through & seal, turn over & repeat, then top up (opps just repeating what been said above -goes to show it decent advice 😉 )
Posted : 20/11/2013 11:13 pm
