Track pump - Road t...
[Closed] Track pump - Road tyres
5 Users
 teef
Just used my track pump to inflate some road tyres to 100psi - it was hard work. Over 90psi I had to lean on the pump with my full body weight - is this normal or is my pump no good?
Posted : 09/05/2015 12:34 pm
Not my experience with my cheap Decathlon track pump. Easy up to 120psi
Posted : 09/05/2015 12:41 pm
 cp
What's your pump? My decathlon one gets to 120 easily without noticing tho much.
Posted : 09/05/2015 12:44 pm
If you're using an el-cheapo pump that was designed for mountain bikes and family bikes and has a fat barrel to deliver higher volume at lower pressure, yes, you will need muscles like a gorilla.
If you're using a good quality skinny track pump with a thin barrel for small volumes at high pressure, you might want to consider going to a gym.
Posted : 09/05/2015 1:01 pm
 teef
Pump - It's a Topeak Joe Blow Max II track pump bought primarily for mountain bike tyres but I just stuck some road tyres on my hybrid.
Any recommendations for same sort of price (£25) that'll do a better job?
Posted : 09/05/2015 1:13 pm
I don't really rate the joe blows tbh but that doesn't really sound right- I had a Sport and it had no problems with 100psi.
My Air Towers do road tyres fine and are pretty cheap. They're also pretty shoddy frankly but they're effective.
Posted : 09/05/2015 1:21 pm
