TPU innertubes?
TPU innertubes?
21 Users
20 Reactions
I'm curious about these new-fangled innertubes and hope to benefit from others' experience...
All of the household bikes (mtb, gravel and road) have been running tubeless tyres for years now. I love tubeless and have no intention of going back to innertubes, however, I still carry an emergency innertube for the rare occasion that tubeless lets me down. I think this has only happened twice in the last two years... that's a fair amount of miles. The two occasions that I've needed to use an innertube are when a metal spike pierced through the tyre and rim tape, and once when my CO2 / pump failed.
I have continued carrying around big, old, heavy and smelly innertubes but rarely need them. So, I got to thinking... maybe TPU tubes would save me space in my saddle-pack or inside frame storage? And be a bit lighter? And less smelly?
My main questions: Are the cheapo ones as good as the more expensive ones? Are they super-fragile? Will they last when stored? Do I have to buy the exactly correct size? Recommended brands or sellers? Anything else?
Thanks in advance 🙂
Posted : 28/10/2024 10:44 am
I have used ride now tpu tubes on road bike since April. One puncture, carry then as spares. I do put them in a zip lock bag to protect them in saddlebag.
Posted : 28/10/2024 10:55 am
So TPU is puncture proof, or more puncture resistant than butyl tubes? I take it they're a bit more expensive then?
Posted : 28/10/2024 11:09 am
Ridenow (pink) get recommended a lot and are what i use. They work out about £5 each on aliexpress if you order >1. There's also the brilliantly named "Off Bondage" (presumably a mistranslation of Un-Chained) purple tubes, Cycloami (green) and thinkrider (green) which all seem much the same.  There's obviously still a fair bit of R&D going on as I've got 3x different variations on the ridenow tubes already.  Early ones had a fragile valve/tube interface, then they got reinforced and aluminum valve stems, the newest ones have plastic valve stems with non-replaceable cores and a sort of push-fit lockring.
I've used them on a couple of road bikes (my actual road bike in it's winter tyres and my track bike as the outdoor velodrome is too puncture prone and abrasive concrete surface to make tubs viable. And so far touch wood neither has had a puncture.  I still think tubeless is better, but for winter road riding I figure I'll trade a known easy puncture fix for the potential faff of a tubeless tyre issue even if it is infrequent.
I know at least one friend who's had one perish in a backpack.  But I've had butyl tubes do that waiting for a tubeless puncture so it's not really a new issue. I've stopped using a saddle bag and just put tools/spares in my back pocket so they don't get left wet in the shed for long periods. Maybe that'll help.  They do fold up incredibly small, I've got two strapped to my smallest multitool (about the size of a small matchbox) and the tool is still the biggest part of the bundle.
Downside is apparently they are difficult to re-use.
Posted : 28/10/2024 11:10 am
Latex have lower rolling resistance. I have a Tubolito S for emergencies. Used it this weekend. Folds small (tiny in fact), inflated fine, was better than the thick butyl tube it replaced out on the road. The puncture was due to rubbing at the seam of the rim tape, and when I removed the Tubolito there was no abrasion. Then the rim tape slow punctured another butyl tube! Now fixed properly.
Finally when I read some more, the lightest Tubolitos can't be used with rim brakes. I like the idea, the company have done the research for sure (with bicyclerollingresistance) and I believe in rewarding innovators. One of our club mates had a disaster with a double puncture last year and plastic tubing everywhere which initially put me off the generic versions. But latex tubes have the lowest rolling resistance if you don't mind topping them up daily - lower than tubeless if you go for non tubeless road tyres.
I was thinking of buying two more 40g versions as they cover 23-30c widths in a single tyre - which I thought surprising.
Posted : 28/10/2024 11:11 am
https://singletrackmag.com/forum/topic/tpu-tubes-better-equal-to-tubeless-on-the-road/
My own experience (road), used two of them so far and they have gone up OK at the time but then been completely flat and unable to hold air 24h later. One of them installed at home, one when I got a puncture on a ride, both times I checked thoroughly for sharp stuff inside the tyre both before installing the TPU tube and after it had then failed.
Posted : 28/10/2024 11:14 am
So TPU is puncture proof, or more puncture resistant than butyl tubes? I take it they’re a bit more expensive then?
99% of the puncture resistance is the tyre so any difference is going to be marginal.  I think it's probably safe to say they're not noticeably worse.
The advantage though is that they weigh less than half the lightest latex tubes which are themselves half the weight of a standard tube, don't leak like latex (or even continental supersonic butyls), and so for I'd say are more robust (I've ripped the valve stem off a brand new conti supersonic before).  And fold up much smaller so don't take up space.
Bought direct they're about £5, so the same price as a regular tube and half the price of a fancy lightweight one.
Posted : 28/10/2024 11:21 am
t3ap0t, tenfoot, t3ap0t and 1 people reacted
"Latex have lower rolling resistance"
Huh? What resistance is there, the tube is inside the tyre?
Do you mean a lower rotational mass due to the lighter weight?
Posted : 28/10/2024 11:34 am
Just be careful with repairs, I followed the Ridenow instructions a bit too literally and didn't bother sanding tube before applying the supplied self adhesive patch, which fell off again shortly afterwards.
Sanded tube, applied new patch, and it's still inflated (as mentioned, holds air longer than latex).
I was a bit put off by how easily it seemed to puncture, 10km in to my first ride with TPU and I had pinch flatted without even realising what I'd hit. Am putting it down to bad luck but have sort of gravitated back to latex in the meantime...
Posted : 28/10/2024 11:43 am
The ability to deform around small variations in the surface is a big part of rolling resistance, which is why softer tyres are actually quicker (to a point). Regular tubes add alot of stiffness to a tyre which reduces their ability to confirm to the surface, increasing rolling resistance. Latex and TPUs don't add so much.
Posted : 28/10/2024 11:52 am
dc1988, honeybadgerx, honeybadgerx and 1 people reacted
“Latex have lower rolling resistance”
It is how the tube interacts with the tyre when rolling along the road - look up hysteresis
Posted : 28/10/2024 11:53 am
dc1988, supernova, dc1988 and 1 people reacted
I've got a Tubolito that I got as a spare for bikepacking trip, attracted by the size more than the weight. I didn't need it, but perhaps it's telling that when I'm using my gravel wheels and space isn't so much of an issue I take a regular butyl as a spare rather than the Tubolito. Maybe I read too many scare stories about their durability.
Posted : 28/10/2024 12:16 pm
 look up hysteresis
Oh... I was just about to then the doorbell went. Maybe later?
Much later.
Posted : 28/10/2024 12:22 pm
blokeuptheroad, nuke, augustuswindsock and 3 people reacted
I tried the BMX ones and they wouldn't hold air. On inspection the valves weren't welded to the tube properly. And this was both tubes from a matching pair so 100% useless in my experience.
Posted : 28/10/2024 12:52 pm
Much later.
About 10 free watts for a change in inner tube and pumping them up daily? That's a decent improvement. They also sound so much better in my carbon faired alloy race wheels with Corsa tyres. I'm unconvinced by the cheaper generic ones. Research and Development costs money. But the lightest aren't suited to rim brakes.
https://www.bicyclerollingresistance.com/specials/tpu-inner-tubes has plenty of data and is a great site. They also test for the manufacturers for R&D.
Posted : 28/10/2024 2:52 pm
I have some ride now ones and they don't seem to hold air as long as butyl tubes but they last long enough to get you home. They're half the size and half the weight and £5 so a no brainer as a spare for me. As soon as I get home i would remove them and go back to tubeless anyway.
Posted : 28/10/2024 5:24 pm
I bought RideNow for my wife's road bike.
Two went flat immediately from new. The new ones with clear plastic value stems. One leaked at the base of the stem, one was full of pinholes all the way round.
We have two spare but she hates faff, and doesn't like being stranded so I've yet to persuade her to try the other two in place of some fairly heavy buyl ones.
Were we just unlucky? (I followed the instructions, and have fitted hundreds of tubes in the past).
Posted : 28/10/2024 5:44 pm
I bought some ridenow tubes from eBay for my road bike, I put them in, did a 40 mile approx ride, no problem, next morning, flat tyre, replaced with another  ridenow, been perfect ever since, no punctures, that was over 18 months ago. That said I’ll have jinxed it now!!
bought a 29er as a lightweight spare for my tubeless mtb, but it fell out the frame-strap somewhere in Guisborough woods, you’re welcome to do a ride there, if you find it, you can keep it, there might be a dinky trail tool nearby too!!
Posted : 28/10/2024 7:07 pm
Im running Pirelli P zero smart TPU tubes on my road bikes, weigh 35 grams and good for disc and rim brake wheels
Gave up with tubeless on the road bike, great for sealing small punctures but anything bigger then me my bike and anyone close behind me just got covered in sealant, then i got even messier when having to fit a tube beacause a bacon strip wont stay in due to the high pressure and then i get even messier once home and stripping it all down to fit a mushroom plug to make a proper repair and trying to get sealant out of £200 worth of lycra
With the Pirelli smart tubes and a set of tube type tyres i save around 120 grams per wheel compared to running the same tyre in the tubeless version with sealant and valve
Ive not needed to pump them up too often, maybe once every 5 days, they are fine to use Co2 in also
No punctures yet in 1000 miles, i know it will happen at some point but i also know i wont be covered in sealant!
Posted : 28/10/2024 10:06 pm
So in summary,  first hand anecdotal experience says they're a bit of a mixed bag? Maybe better to go with the more expensive branded ones as it *seems* QC is a bit variable on the eBay cheepos? I'm all for a bit of budget weight saving and run Supersonics currently. IIRC, they're ~50g in skinny 700c? So mebbies -15g per wheel saved... Do they ride nice and plush like latex?
Posted : 29/10/2024 9:42 am
I've been running some of the cheapest available on Aliexpress on the Canyon for over a year now.
love them, hold air just well but the valves are dogsh*t.
At a couple of quid each I cant really complain but its probably time for an upgrade with some of the newer ones
Posted : 29/10/2024 10:47 am
I dunno, mine (ridenow) across 2x bikes were all fine, they are more fiddly to fit through, it'd be very easy to trap it against the rim and end up "full of pinholes all the way round." And neither bike seems to leak noticeably, I check the pressure a couple of times a week before club rides but in a 25c tyre it's impossible to tell if it's lost pressure or it was just breaking the seal on the valve.
Maybe I just got lucky.
I do worry about the spare getting damaged.
Princess and the pea territory here. It's winter so I'm not running tyres nice enough to notice on the road bike, and the track bike tyres are too hard to notice.
I doubt it. That's basically the same as rolling resistance, how easily does the tire deform over the ground and spring back.  And TPU is noticeably more like a harder plastic compared to latex.  So the gains made by weighing substantially less are working against that.
I like to think of new tech the other way.  If TPU was the default and someone invented latex and butyl tubes, would anyone switch? And I think for me it's a no for any bike I'd consider running latex or supersonic tubes the TPU tubes at worst carry the same drawbacks around fragility, but at least (IME) they don't leak overnight.
OTOH my commuter still has butyl tubes because it's not a bike I spend £ on, it just has to dop it's job.  Maybe when I sort new tyres for it I might but there's another winter left in the current ones.
Posted : 29/10/2024 10:56 am
Thanks for all of the input on this. I've ordered a selection of Tubolitos to cover MTB and gravel bikes. I hadn't realised they made so many different versions; I've gone for their middle option rather than lighter or more puncture resistant.
Thanks again
Posted : 29/10/2024 11:40 am
benpinnick
The ability to deform around small variations in the surface is a big part of rolling resistance, which is why softer tyres are actually quicker (to a point). Regular tubes add alot of stiffness to a tyre which reduces their ability to confirm to the surface, increasing rolling resistance. Latex and TPUs don’t add so much.
There's also the added friction of the tyre and tube rubbing against each other as one or the other deforms
Posted : 29/10/2024 12:05 pm
Before I bite the bullet and get some nice teenie tiny tubes. I usually carry a 27.5 in knowing it will stretch for my GFS 29er.
Same with these tubes? Or go 29 knowing it will fit in my 27.5?
Thanks
Posted : 21/11/2024 9:44 pm
I don't imagine they stretch well
Posted : 22/11/2024 6:24 am
When I was shopping for the Tubolitos, I'm fairly certain I saw some listed for 29 and 27.5
Not used mine yet, although they are in the spares packs ready to be deployed. Funny looking and feeling things!
Posted : 22/11/2024 6:47 am
I have been carrying one this season but haven’t used it, much nicer to pack than butyl tubes.
Have to say I am slightly worried about plastic valves - saw few complaints online about them breaking during inflation with minipump. It is very easy to imagine that happening to me at remote location at some mosquito infested trail.
Posted : 22/11/2024 7:52 am
I've got some of those RideNow ones arriving today. I was going to use them on my commuter to drop a chunk of weight out of the wheels and maybe improve ride quality a tad.
Given I only have to top up my tyres every few weeks at most at present, will I feel like I'm forever pumping my tyres up?
Ta
keith
Posted : 22/11/2024 9:49 am
