Tough rear rim reco...
[Closed] Tough rear rim recommendations
5 Users
Eldest_oab has added a 14th dent to his rear rim (!). It seems to be very weak alu - he is running DH carcass HansDampf and good pressures.
It's a 5 month old DT Swiss E1900 wheel, on 170mm 29er Endooro racing monster truck.
So, tough 29er rim for 2.3ish tyres and an abusive 17 year old.
Also a 29er insert.
#beltandbraces
Posted : 13/10/2019 5:50 pm
28 spokes? Think I'd be checking the ERD of EX417 or EX511 to see if they are a straight swap
Edit: because they are strong rims and I'd like to save money/hassle getting spokes
Posted : 13/10/2019 6:04 pm
on the insert front I really like the Rimpacts but I don't think they will last five minutes under the kind of abuse you are describing so I'd look for something tougher.
Posted : 13/10/2019 6:08 pm
If sticking with 28h on the rear then I'd go for at least a EX471 or 511 as above. Very tough rims.
I flogged those wheels and went straight to 32h ones on mine, using a Rimpact insert on the rear - which I rate highly.
edit - If he's doing that damage with DH tyres then get the burliest rear wheel possible!
Ex471 or ex511
Inserts, flat tyre defender, cushcore, basically one of the tougher ones.
And lastly, a pressure gauge, so he doesn't leave the house with no less than 35psi!
Posted : 13/10/2019 8:21 pm
EX471.
However personally if he is denting the rim regularly I would up the tyre pressure slightly, or accept for max traction you replaced the rims regularly (ok for pro/sponsored, expensive for hobby), (or switch to lifetime warranty carbon rim, £££).
Posted : 13/10/2019 8:52 pm
