Torver Walna scar a...
Torver Walna scar advice
4 Users
Anyone know if it is possible to ride the BW through the forest above Torver on the way to Stephenson ground, heard there was logging storm damage awhile ago, best to avoid?
Posted : 10/10/2022 4:32 pm
Did it on 7 August, you do have to miss out a couple of sections through the forest. You can still make it round the fire roads and do a couple of good sections, but I would've found it tricky to navigate had I not been with someone who knew the way! It all looked unfamiliar because of the damage and logging. Don't be put off though, you can still make it through. It might all be sorted by now.
Posted : 10/10/2022 4:40 pm
 P20
As above, some rideable bits, some felled bits. It wasn’t horrific
Posted : 10/10/2022 7:23 pm
T'was fine the other week. Just the last bit before you hit the road @ Stephenson grounds has trees across it but you can take a slight diversion onto the road.
Posted : 10/10/2022 10:21 pm
This is the ride I did, not sure if you can work out the way through from this
https://www.strava.com/activities/7596664143
Posted : 10/10/2022 10:33 pm
