Torque cap spacers
[Closed] Torque cap spacers
7 Users
I have a set of pikes the accept torque caps. Because my wheels are boost converted I cannot use end caps. Other than the EU only and hard to find at that universal Newman torque cap adapters has any found a good solution. These things;
I've seen the STL files for getting some printed. That's plan z.
Posted : 02/02/2022 12:30 pm
You dont actually need them, they just make a normal 15mm wheel easier to fit.
Posted : 02/02/2022 12:38 pm
And even that’s debatable. I’ve got 2 Torque Cap wheels both of which are more faffy to get between the fork legs. One of them being particularly great as the caps just fall off with ease
Posted : 02/02/2022 12:42 pm
Yeah I know I don't need them. It's making wheel fitting easier I'm after as this bike is stored wheel off. It's a faff getting them lined up while holding the bike up that annoys me.
Posted : 02/02/2022 12:51 pm
You want a 22x18mm (iirc) self adhesive washer - I've probably got some left somewhere from doing mine. (I should do is just where the rest of the bag went, I'll see if I can find them)
Stick on the dropout, cut out a notch with a Stanley knife and Bob's your mother's brother.
About 60p plus post for a dozen or so when I got mine years ago.
Posted : 02/02/2022 12:58 pm
Perfect. I was hoping there was an easy DIY solution. Cheers will look for those.
Posted : 02/02/2022 1:48 pm
31mm external by virtue of a quick Google
This sort of thing
https://www.ebay.co.uk/itm/Nylon-Plastic-Washers-Adhesive-Backed-in-Black-and-Natural-All-Sizes-M2-to-M24-/310418506592?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
I've a suspicion my 18mm I'd is wrong but should be able to check ready enough. Mine were a standard size so judging from the chart there about m22 or 24.
OD doesn't really matter once they're stuck though, just helps alignment when you fit them
Posted : 02/02/2022 1:50 pm
Cool, thanks. Search brings up a page that details 21mm OD for normal end caps, 31mm OD for torque caps.
Posted : 02/02/2022 7:53 pm
Interested in this too
Mavic ones seem impossible to get in UK and post brexit if EU sites even ship to UK tax is ridiculous
Posted : 02/02/2022 9:19 pm
I've pm'd you Nixie but I'll add it here for the benefit of future searches
I got m22 washers for mine and they're pretty much spot on. https://www.abouttownbolts.co.uk/product/nylon-washers-adhesive-backed-in-black-and-natural-all-sizes-m2-to-m24/
and @kimbers it seems
Posted : 02/02/2022 9:20 pm
 nre
Also interested in this! Thanks for the info @dangeourbrain will give the M22s a try!
Posted : 03/02/2022 7:35 am
Cue spike in 10 packs of M22 sales from About Town Bolts. Good PSA, thanks.
Posted : 03/02/2022 8:41 am
 nre
Just to follow up, those M22 self adhesive washers are absolutely spot on for this job! Only needed a single washer chopped in half to do both sides!
Thanks @dangeourbrain, fitting my front wheel is now a pleasure rather than a pain 🙂
Posted : 08/02/2022 9:41 pm
Glad they got you sorted (but unless you load that bike onto a wheel off roof rack I'm afraid you'll never know the true amount of pleasure they could bring nor the pain you've missed 😉)
Posted : 08/02/2022 9:52 pm
 nre
That does indeed sound like a whole lotta pain!
Posted : 08/02/2022 10:21 pm
I load mine with boost forks onto a front wheel off rack with non boost fork up (still have a set of non boost forks on other bike). Trying to slot the boost spacers in while lining the axle up was horrible.
Posted : 09/02/2022 8:34 am
Is it a loose spacer for that too or do they at least plug into the fork up thing?
Posted : 09/02/2022 8:41 am
Loose spacers! The worst kind. Definitely need to sort something better.
Posted : 09/02/2022 9:04 am
